    (solved) fba-libretro change hotkey (coin input not working) and exit mame
    solved fba-libretro hotkey coin input mame
    3902
    • 0zzy
      0zzy last edited by
      Hi all, i have installed  realbox 3.2.11  i'm trying to play fba-libretro with arcade control panel home made. It works great but insert coin button does not work on fbalibretro.. How can i fix it?
      • digitaLumberjack
        Hello, you don't have to install the drivers. Just activate it in recalbox.conf : https://github.com/digitalLumberjack/recalbox-os/wiki/recalbox.conf-(EN)
        • 0zzy
          0zzy last edited by
          Hi retroboy, i have read a few minutes after  my original post that "The mk_arcade_joystick_rpi is fully integrated in the recalbox distribution" , so i have tried to enable it in the recalbox.con, and it works! Tnx for the info retroboy and great work!
          • 0zzy
            0zzy last edited by
            edit
            • 0zzy
              0zzy last edited by
              I have found, how to change hotkey in  gpiocontroller1.cfg . I have another question, how can i exit from mame?   solved: use (as usual) tab key to config mame and set exit ui with combo: start+Rtrigger
                Hotkey+start but your hotkey must not be on select
                • 0zzy
                  0zzy last edited by
                  hi rockaddicted and tnx, i have solved all my trouble,,for now!
