    How to emulate X68K in Recalbox
    Emulator Arcade/PC/Console
    emulate x68k recalbox
    11
    70
    42151
    • junixbr
      junixbr last edited by
      Hi there,
      How is the best way to emulate X68K using Recalbox?
      I've heard about px68k, in Raspi 2 is slow, but with Rasp 3, has somebody any experience?
      Thanks,
      Junix
      lolo 1 Reply Last reply Reply Quote 1
        hello
        I dont know , but compile and try with raspbian may be
        just https://github.com/hissorii/px68k for @Substring
        0.5 Raspberry Pi について USE RASPBIAN
        ・自前でコンパイルしてください。
        ・インターネットにつながっている状態で、以下を実行してください。
         $ sudo apt-get install libsdl1.2-dev libsdl-gfx1.2-dev
         $ mkdir src ; cd src ; git clone http://github.com/hissorii/px68k
         $ cd px68k
         $ make sdl2=1
        ・GitHub 上のソースが更新された場合は、インターネットにつながっている
        状態で、以下を実行してください。
         $ cd src/px68k
         $ git pull http://github.com/hissorii/px68k
         $ make clean ; make
          not for 4.1, maybe later. What's the point of the emulator ?
            it's a emulator for Sharp X6800 games https://www.youtube.com/watch?v=zmIXovryWrw
            • azvarel
              azvarel last edited by
              If I enter that emulator in the recalbox I simply cry, replay Castlevania and Alice in Wonderland is simply wonderful
              @Substring try to implement this in version 4.1 😄
              Zodian Theme | #SNESProject
                Hello
                I tried to compile in raspbian with SDL2
                it's work with gamepad but It's slow.
                emulator use gfx and X11 and theses things are not in recalbox.
                For a developper it will be easy not for me 😛
                • compile with SDL2 without GFX and X11 but with OpenGLESv2
                • Modify keyboard/joystick file
                azvarel 1 Reply Last reply Reply Quote 1
                • azvarel
                  azvarel @acris last edited by
                  Great news, now expect a developer to manifest. Thanks for the work and dedication @acris
                  come on? @Substring @voljega
                  Substring voljega 2 Replies Last reply Reply Quote 0
                    Substring @azvarel last edited by
                    @azvarel no time to spend on that for now
                    azvarel 1 Reply Last reply Reply Quote 0
                    • azvarel
                      azvarel @Substring last edited by
                      @Substring need not be now, but enter the development list
                      I was excited about this 😃
                        voljega Banned @azvarel last edited by
                        @azvarel I can't do more than @acris if it is slow, it is slow 🙂 although I would oike to have all those japanese computers emulators
                        • lolo
                          lolo @junixbr last edited by
                          @junixbr said in How to emulate X68K in Recalbox:
                          low
                          Same thing with the RPi3, too slow.
                          • azvarel
                            azvarel @lolo last edited by
                            @lolo
                            What I find funny is how A computer from 1987 with a Motorola 68000 CPU 10 MHz, 1MB RAM and no hard drive or of 1993 Motorola 68030 CPU 25 MHz, 4MB RAM and hard drive, do not have an efficient emulation in rpi.
                            I had a Classic XBOX which has a 733 MHz x86 Intel Celeron / Pentium III Custom Hybrid rendering and perfectly emulates through the x68000x emulator all the games, the only emulation that was to be desired was CPS3 which for me the rpi3 caters very well.
                            Would not be able to make a port of this emulator for the recalbox, since they are both "linux" or am I talking screwed up?
                            @voljega, @acris, @Substring is there any basis for this?
                              @azvarel depends if ypur emulator had JIT, or DYNAREC, or such code that is cpu dependant and really improves speed
                              • rtype
                                rtype last edited by
                                did you try this port https://github.com/libretro/px68k-libretro
                                it's not too slow on pi3 ,at least setting 1/2 frame instead Full frame make it pretty usable.
                                  Oh no, I try px68k emulator standalone
                                  • azvarel
                                    @acris try to see 😉
                                      @rtype and @azvarel
                                      I am not a developer and The team is not available, it is at the HFS convention for 3 days 😄 but
                                      I try to compile this core on raspbian
                                      mkdir libretro
                                      cd libretro
                                       sudo git clone https://github.com/libretro/px68k-libretro
                                      cd px68k-libretro
                                      make -f Makefile.libretro
                                      @rtype it's right ? c'est juste ? ou bien il faut des paramètres comment SDL2=1 ou RPI3 ?
                                      mkdir /recalbox/share/roms/px68k
                                      mkdir /recalbox/share/bios/keropi
                                      excecute :
                                      killall emulationstation
                                      /usr/bin/retroarch -L /usr/lib/libretro/px68k_libretro.so --config /recalbox/share/system/configs/retroarch/retroarchcustom.cfg /recalbox/share/roms/px68k/R-Type.dim
                                      I have a red screen 😞 and my keyboard has not F12. lol
                                      It's a problem of compilation core.
                                      I think it^s
                                      make -f Makefile.libretro plateform=rpi3
                                      WIP - it' s theory, a developper need to control.
                                      • config.in
                                      config BR2_PACKAGE_LIBRETRO_PX68K
                                              bool "libretro-px68k"
                                      	depends on BR2_PACKAGE_RETROARCH
                                      	depends on BR2_INSTALL_LIBSTDCPP
                                              help
                                                A libretro sharp x68000 emulator core for ARM.
                                      	  http://www.libretro.com
                                      comment "LIBRETRO_PX68K needs a toolchain w/ C++"
                                      	depends on !BR2_INSTALL_LIBSTDCPP
                                      • Create Package mk
                                      # PX68K
                                      LIBRETRO_PX68K_VERSION = 1e4cefcf8a34478874de3009de7ab9e45701fd43
                                      LIBRETRO_PX68K_SITE = $(call github,libretro,px68k,$(LIBRETRO_PX68K_VERSION))
                                      define LIBRETRO_PX68K_BUILD_CMDS
                                      	CFLAGS="$(TARGET_CFLAGS)" CXXFLAGS="$(TARGET_CXXFLAGS)" $(MAKE) CXX="$(TARGET_CXX)" CC="$(TARGET_CC)" -C $(@D) -f makefile.libretro platform="$(LIBRETRO_BOARD)"
                                      endef
                                      define LIBRETRO_PX68K_INSTALL_TARGET_CMDS
                                      	$(INSTALL) -D $(@D)/px68k_libretro.so \
                                      		$(TARGET_DIR)/usr/lib/libretro/px68k_libretro.so
                                      endef
                                      $(eval $(generic-package))
                                      es_system.cfg
                                        <system>
                                              <fullname>Sharp x68000</fullname>
                                              <name>px68k_libretro</name>
                                              <path>/recalbox/share/roms/sharpx68000</path>
                                              <extension>.dim .DIM .zip . ZIP .img .IMG .d88 .D88 .88d .88D .hdm .HDM .dup .DUP .2hd .2HD .xdf .XDF .hdf .HDF .cmd .CMD</extension>
                                              <command>python /usr/lib/python2.7/site-packages/configgen/emulatorlauncher.pyc %CONTROLLERSCONFIG% -system %SYSTEM% -rom %ROM% -emulator %EMULATOR% -core %CORE% -ratio %RATIO%</command>
                                              <platform>px68k</platform>
                                              <theme>sharpx68000</theme>
                                      	<emulators>
                                      	    <emulator name="libretro">
                                      	        <cores>
                                      		    <core>px68k</core>
                                      		</cores>
                                      	    </emulator>
                                      	</emulators>
                                          </system>
                                        <system>
                                      • Create theme
                                      require graphic guy (use inkscape)
                                      • sharpx6800 folder
                                        • theme.xml
                                        • custom.xml
                                        • DATA
                                          • logo.svg
                                          • game.svg
                                          • console.svg
                                            logo.svg
                                      • add to configgen
                                      emulators["px68k"] = Emulator(name='px68k', emulator='libretro', core='px68k')
                                      • readme.txt /lisez-moi.txt
                                        ### RECALBOX SHARP X68000 ####
                                      Bios require :
                                      "/recalbox/share/bios/keropi/iplrom.dat"
                                      "/recalbox/share/bios/keropi/cgrom.dat"
                                       HUMAN302.XDF required for change memory.
                                      To Acces menu you need to plug keyboard : F12
                                      Put your sharp x68000 roms into the directory
                                      Roms files must have dim .DIM .zip . ZIP .img .IMG .d88 .D88 .88d .88D .hdm .HDM .dup .DUP .2hd .2HD .xdf .XDF .hdf
                                      .HDF .cmd .CMD extensions
                                      rtype 1 Reply Last reply Reply Quote 0
                                      • rtype
                                        rtype @acris last edited by
                                        @acris said in How to emulate X68K in Recalbox:
                                        normalement depuis raspian pas besoin de paramètre.
                                        moi je cross-compile depuis mon hôte linux pour compiler plus rapidement (
                                        make -f Makefile.libretro plaform=crosspi).
                                        Sinon l’émulateur est bien celui de hissorii avec le backport du cpu de yabause issu du fork de kenyahiro. Je ne suis donc pas l'auteur mais j'ai juste fait un portage pour libretro en mixant les 2 .
                                        j'ai enlevé toute les références a SDL et X11 dans ce port .
                                        Le portage est au stade bêta , donc des erreurs/bugs sont a prévoir.
                                        Sinon ce n'est pas une version spécifique ARM , il fonctionne aussi sous linux et windows .
                                        A noter cependant qu'il existe une version spécifique pour ARM utilisant le cpu asm ARM cyclone (celui de picodrive)
                                        https://github.com/chiorex/px68k/tree/speedup qui doit être plus rapide pour les cpu ARM.
                                          @rtype
                                          j'ai trouvé ton archive sur libretro et testé ton core sur recalbox et ça fonctionne. Mais ma propre compile sur raspbian n'a pas fonctionné. Je recommencerai à l'occasion.
                                          Penses tu qu'une version arm serait mieux pour le raspberry ?
                                          comment arrives tu à changer la ram alloué au jeu ? j'ai pas réussi.
                                          • rtype
                                            @acris pour la ram il faut booter avec une disquette HumanX style HUMAN302.XDF , et lancer switch.x puis changer la mémoire (4mo est une valeur safe ).
                                            https://www.youtube.com/watch?v=XlRQLcqueas
                                            pour la version cyclone , je n'ai pas testé.
                                            100.9k
