    Solved Ipega doen'ts recognize as controller, it detects no controller
    GamePad/GPIO/USB encoder
    ipega doents recognize detects
    14082
    • A Former User
      A Former User last edited by
      like the title, i paired the ipega bluetooth controller but it didn't recognized as a controller, when press home + X(Controller mode) it detecs no controller, but when presses home+A it detects as keyboard, but in that mode i doen't work, what should i do?
      • A Former User
        can someone help?
          paradadf Staff last edited by
          You should try giving more information about your controller and your setup. What ipega? What raspberry pi? Which version of recalbox? Did it work before or never?
          Which modes do you have available on your controller? Etc...
          A Former User 1 Reply Last reply Reply Quote 0
          • A Former User
            A Former User @paradadf last edited by
            @paradadf It's the ipega 9025.
            Im using raspberry pi3 model b, the recalbox is in the last update avaliable, 4.01 i think, not sure, i updated it last week.
            the controller has gamepad mode(home + x), also has the keyboard mode (home+a), and the icade mode(home +b) and the spp mode(home +y, for the gamebits games).
            On the normal gamepad mode(home + x) it doen'ts recognize on the recalbox after pairing, it shows no gamepad recognized, on the keyboard mode it recognize and works on the menu, but in game it doen't work, i tested on snes.
              paradadf Staff @Guest last edited by digitaLumberjack
              you have two options... either update to 4.1 unstable and it will work out of the box or use the search function of the forum to find thd thread related to that controller containing the instructions to make it work.
              A Former User 2 Replies Last reply Reply Quote 0
              • A Former User
                @paradadf I already searched on the forum and that didn't helped me, then i opened the topic.
                And now i already flashed recalbox 4.1, and when i enter to search a bluetooth controller it keeps saying "No controllers found" With, and without the bluetooth adapter usb.
                • A Former User
                  @paradadf i tried to search a few time then it found the ipega, but it still say "No controller detected".
                  Can't really someone help me with this sad situation?
                    have you change recalbox.conf accordingly?
                    global.inputdriver=sdl2
                    • A Former User
                      @paradadf yeah, i did, now it shows just the mac, not "ipega bluetooth controller", but still does not detect in gamepad mode.
                        please, pair the controller and unplug/unpair any other device if possible and follow the instructions given here:
                        https://github.com/recalbox/recalbox-os/wiki/Recalbox-support-(EN)
                        Share your support files here.
                        Pair it in the controller mode and don't bother with any other one.
                        Use 4.1 for this.
                        • A Former User
                          @paradadf here's the file:
                          http://www.mediafire.com/file/8ocv6wxuyxsydxd/recalbox-support-20170422182254.tar.gz
                            Substring @Guest last edited by digitaLumberjack
                            how can we help if you don't even mention your recalbox version ?
                            • A Former User
                              A Former User @Guest last edited by A Former User
                              @leotrix14 said in Ipega doen'ts recognize as controller, it detects no controller:
                              @Substring said in Ipega doen'ts recognize as controller, it detects no controller:
                              @leotrix14 how can we help if you don't even mention your recalbox version ?
                              I mencioned up there that i was using the last stable, then i flashed the 4.1 version because paradadf said it was going to work right out the box. The exactly version is the Build 11603325
                                somehow everytime a user says he/she has an ipega 9025, the internal controller name is different... Try this:
                                Execute the following three commands (one after another):
                                mount -o remount, rw /
                                echo 'SUBSYSTEM=="input", ATTRS{name}=="ipega media gamepad controller", MODE="0666", ENV{ID_INPUT_JOYSTICK}="1"' >> /etc/udev/rules.d/99-joysticks-exotics.rules
                                reboot && logout
                                Just for the record, it is needed to edit recalbox.conf so it reads (change auto for sdl2😞
                                reboot and try again.
                                If this rule works, comment it here so we can add it by default. Again... this only works on 4.1 upwards.
                                Don't do this part yet: I'm not sure anymore, but if your controller (assuming you really paired it in the right "controller" mode) is detected as a keyboard, you might need to add the following rule to the usbhid.conf:
                                # IPEGA
                                options usbhid quirks=0x1949:0x402:0x040
                                  the pad doesn't even get listed in /dev/input ... so there is sthg wrong on the OS side. BT or kernel
                                  • A Former User
                                    @paradadf D**n, that made it work!!!!! just followed these commands straight on recalbox F4 console and then the magic happened, after pairing it started recognize as a gamepad controller! hope this topic help someone else too!
                                    And a simple question, you guys call 4.1 as "Instable", whats the problem with it? tried with a few games and its looks normald and fluid to me.
                                    And thanks again!
                                    Regards from Brazil!
                                    • Neil_Hines
                                      Neil_Hines last edited by
                                      It is a really great topic and you guys give the great suggestion. I will try what you guys say hope it will also work for me. 🙂
                                        you see what is working, i see that there are many bugs left 😉 It will be marked stable when it does run as expected AND the upgrading process from 4.0.x to 4.1 is safe, we can't miss that.
