    Mame in Recalbox 4.1
    Emulator Arcade/PC/Console
    mame recalbox 4.1
    10308
    • RustyMG
      RustyMG last edited by
      Hi all,
      After spending months setting up my Recalbox 4.02 on a 64gb microsd card, I was thinking of trying out the unstable 4.1 release with my games going on a 128gb usb stick (so I can try the large file Dreamcast and PSP games).
      But, before I start, I'm reading conflicting posts as to what the default emulator and Rom set is for MAME in 4.1
      I've done a lot of work with my MAME Roms, removing all duplicates etc, so does 4.1 use the same lr-mame2003 as default, with the same 0.78 Romset?
      I don't wish to lose all my hard work.....
      Many thanks in advance.
      Sinclair ZX Spectrum 48k "dead flesh" keyboard, Commodore 64, Amiga A500, Amiga A1200, CD32, PC Engine, PS1, PS2, PSP, Nintendo DS, Dreamcast, Wii, XBox 360, Xbox One-X, Pi2, Pi3, Pi4 owner, ARRM contributor ( http://jujuvincebros.fr/wiki/arrm/doku.php ).
      RustyMG 1 Reply Last reply Reply Quote 0
      • RustyMG
        RustyMG @RustyMG last edited by
        Apologies. Just realised I posted this in the incorrect section 😞
          Hello @RustyMG
          recalbox 4.1 use :
          • romset mame 0.78
          • romset fba libretro 0.2.97.39
          • romset mame 0.106 for advance Mame (standalone emulator)
          • RustyMG
            RustyMG @acris last edited by
            @acris Thank you for the prompt reply πŸ™‚
            • kelv
              kelv last edited by
              Hello I checked that there is also advance mame and it's using romset 0.106 . Does anybody tested any tekken game or souledge? If so, pls are they working fast? THX
              Raspberry Pi model: RPi 3b+
              Recalbox build : 7.0.1 DragonBlaze
              Hardware: MicroSD UHS 128 GB up to 80 MB, Class 10 and 2.5 A Power Supply.
              Overclocked: 1485 MHZ
              Controller(s): Wired Xbox 360 PAD (working perfectly on any other game/emulator).
                voljega Banned @kelv last edited by
                @kelv those games won't work, 3D games on Mame are software emulated, so very slow even on a correct pc, you can forget it on pi.
                Try them on psx it's the best solution and they are anyway more nicely rendered than on mame
                • kelv
                  kelv last edited by
                  @voljega THX you are right that the workaround is to use PSX however I like to play the original one πŸ™‚ .BTW, I downloaded the romset 0.106 and even the games are not working fine so I will stick to the lr-mame2003. Besides I think in the future the one that will be supported will be lr-mame 2010 or any other superior. THX again
                    don't forget to switch emulator and core in options emulators.
                    Emulationstation menu > advanced parameters > parameters emulators >
                    • emulator : advance mame
                    • core : advance mame
                    • kelv
                      kelv last edited by
                      @acris I only changed emulator not the core... πŸ™‚ Thx for the hint. I will change the core too but I will need to check that after scrapping all the mame2003 games (1500 remaining)
                        Advance mame not support subfolder.
                        Games will be in mame folder not subfolder and without keyboard advance mame doesnt start.
                        https://forum.recalbox.com/topic/7241/advance-mame-4-1/55
                        • kelv
                          kelv last edited by
                          @acris oh I had them in a subfolder 😞 But If I don't have them in a subfolder, they will be overlaped with the mame2003 ones and that's and issue 😞 THX for letting me know
                            @kelv pu the mame2003 ones​ in a subfolder and the advmame ones in root folder ?
                              acris @voljega last edited by
                              @voljega said in Mame in Recalbox 4.1:
                              yes, you do it.
                              If you change advance mame folder, you need to change for each update.
                              Copyright Β© 2021 recalbox.com
