    Recalbox partition
    recalbox partition
    • aken
      aken last edited by
      Hi im new to the pi world... ivd just purchased a pi3b with a 16go sd card ivd succefuly installed recalbox and raspbian via the noobs install setup... the problem i have is that i wanna pu roms onto the pi now and i only have 3go of space... how can this be possible ?? when i connect to the recalbox from my windows pc in the monitoring section i see 3 partitions
      dev/root / 1.9Gio
      dev/mmcblk0p8 / root 59Mio
      dev/mmcblk0p10 / recalbox/share 3.7Gio
      is there anyway that i can use the whole 14.2Go that i have on my sdcard ???
      thanks
        paradadf Staff last edited by
        Noobs divide the partitions equally between the installed OS's. The only way to change that is to pre-download the noobs packages and manually edit the respective json files. Something about expand false true and manually inputing the partition size. I've never done it before but read about it on internet.
        100.8k
