    After 4.1 update, LED doesn't work, but power button does...
    GamePad/GPIO/USB encoder
    4.1 update led doesnt button
    3957
    • xtreemsurf
      xtreemsurf last edited by
      I have been using a momentary switch and an LED with no problems. After the upgrade to 4.1, the LED turns on when the Pi first turns on, but then turns off once Recalbox is loaded. The power button still works perfectly doing a startup/shutdown procedure. Is anyone else having this issue with the LED? Thanks!
      azvarel 1 Reply Last reply Reply Quote 0
      • azvarel
        azvarel @xtreemsurf last edited by
        @xtreemsurf
        I have used system.power.switch=PIN356ONOFFRESET without problems, even with cooler fan.
        Zodian Theme | #SNESProject
        xtreemsurf 1 Reply Last reply Reply Quote 0
        • xtreemsurf
          xtreemsurf @azvarel last edited by
          @azvarel said in After 4.1 update, LED doesn't work, but power button does...:
          @xtreemsurf
          Thanks for this! Do you use a momentary switch with this?
          • azvarel
            @xtreemsurf Use, power button, reset, led and cooler
            • xtreemsurf
              @azvarel
              I use a momentary switch...but this worked! It corrected the LED issue and the momentary switch still functions correctly.
              Which pins did you connect your fan to? Thanks!
              • azvarel
                @xtreemsurf
                pins 4 and 9
                alt text
                gmgman xtreemsurf 2 Replies Last reply Reply Quote 0
                • gmgman
                  gmgman @azvarel last edited by
                  @azvarel you can also use pin 1 and 9 for the fan. I found that if you use one of the 5V Pins the fan is too loud, 3V is way quieter and it's still cooling nicely.
                  • azvarel
                    azvarel @gmgman last edited by
                    @gmgman my fan is 5v and is very silent 😄
                    • azvarel
                      I left it running normal, because where I live it is an unbearable heat (it is almost the desert of the Sahara) is the that it gives to live in tropical country.
                      • xtreemsurf
                        @azvarel
                        When you connect the fan there, does it turn on/off when you use the power button...or does the fan stay running constantly, until you pull the power cord out? Thanks again!
                        • azvarel
                          @xtreemsurf
                          It stays on even with the rpi in standby, so I put a key behind the SNES to turn it off.
                          Click #SNESProject on my signature, which you'll see
                          • xtreemsurf
                            @azvarel
                            Very cool...thanks!
