    Black screen when returning from emulators by pressing Directional PAD, Solutions ????
    returning pressing directional pad solutions
    4228
    • Carlos Eduardo Valcamonico
      Carlos Eduardo Valcamonico last edited by acris
      Hello everyone, I do not know if they have had similar problems, it is the following; I use 2 parallel wireless controls PS3 running successfully, but when I exit the emulators and press the directional PAD return to the menu only that I see nothing, it gets all black, so that I go back to see the recalbox menu I need to press and enter any game And when I get out I do not press any directional of my control, would anyone know why that happens? I changed the theme, without success, Thanks ....
        voljega Banned @Carlos Eduardo Valcamonico last edited by
        @Carlos-Eduardo-Valcamonico what is your recalbox version ? Does it happen on all emulators ?
        Carlos Eduardo Valcamonico 1 Reply Last reply Reply Quote 0
          paradadf Staff last edited by
          I've read that changing the transition style in UI Settings helps.
            Carlos Eduardo Valcamonico @voljega last edited by
            @voljega ,
            Thanks, I tested on Batocera 5.5 and also on 4.1 Unstable on my PI3 ...
              Carlos Eduardo Valcamonico @paradadf last edited by
              @paradadf Yes, you hit, I changed from fade to slide and the error minimized, but while I do not stop pressing the directional does not return to the menu, kkkkkk madness, madness, madness .....
                @Carlos-Eduardo-Valcamonico returning to tge menu is hotkey + start, notjing to do with dire tional.
                Did you configure your pad in the menu ?
                  Substring @Carlos Eduardo Valcamonico last edited by
                  @Carlos-Eduardo-Valcamonico This is not the batocera forum. You didn't even mention on which architecture you're testing.
                    @voljega , Yes, everything is working and configured ...
                      Carlos Eduardo Valcamonico @Substring last edited by
                      @Substring , Hello , I use Recalbox in Raspberry PI 3 and also in PC both have the same error quoted above can help me moderator?
                      Pepe 1 Reply Last reply Reply Quote 0
                      • Pepe
                        Pepe @Carlos Eduardo Valcamonico last edited by
                        @Carlos-Eduardo-Valcamonico If you do not press any key on keyboard or direction on the control between the output of the emulator and the load of the emulationstation screen, what you mention does not happen.
                          Carlos Eduardo Valcamonico @Pepe last edited by
                          @Pepe , Exactly, if I do not press anything after leaving the emulators everything works perfectly ....
