    Vertical mame games
    vertical mame
    7473
    • proteusy
      proteusy last edited by
      Hi, i have build a cabinet with a rotating monitor, so i can play vertical games like arkanoid. Is there a way to have vertical games start rotated?
      proteusy 1 Reply Last reply Reply Quote 0
      • proteusy
        proteusy @proteusy last edited by
        Is there a way to rotate games 90 deg?
        Thx.
          Hi,
          menu mame -> R2 Button or TAB keyboard.
          or
          in retroarch > quick menu options > tate mode.
          proteusy 2 Replies Last reply Reply Quote 0
          • proteusy
            proteusy @acris last edited by
            @acris said in Vertical mame games:
            retroarch
            Thank you acris, will try tate right away.
            Regards
            • proteusy
              @acris - I managed to rotate the screen 90deg, but now all games, even the horizontal ones play rotated. Is there a way to apply the rotation only to vertical games?
                Substring @proteusy last edited by
                @proteusy that's a development i'll do in a few weeks for recalbox 4.1
                • proteusy
                  proteusy @Substring last edited by
                  @Substring - Sweet! Will be watching you 😉
                    @proteusy by the way, the TATE mode should only work for games where height is bigger than width (therefore games with a rotation). It shouldn't rotate all games. Anyway the TATE mode has a fail : it doesn't rotate according to what the "rom driver" specs. So, it works fine with roms that are ROT90, but ROT270 games are upside down.
