    Moving from 16GB to 32GB
    recalbox 16gb 32gb expand
    • chubsta
      chubsta last edited by chubsta
      I currently have Recalbox set up very nicely on a 16GB card, unfortunately I miscalculated the amount of space i would need to am looking to get a 32GB install.
      I see that it is not possible to expand the filesystem on an existing card, so my idea is that i connect to my existing card vis sftp and transfer all the stuff over that i need to keep - roms, images, kodi settings etc - and then transfer them back to the new 32GB card once i have done a basic Recalbox install on it.
      So my questions are:
      will this work?
      what files and folders do i need to transfer to ensure the new 32GB card works as a 32GB card but it has the same recalbox setup - roms, images, kodi, themes etc - as the old card? For instance, do I just copy the 'recalbox' folder which contains configs, share (and therefore roms etc) etc?
      What would i need to transfer over to ensure all my Kodi stuff is still there as that took me ages to sort out!
      • lackyluuk
        lackyluuk Translator last edited by lackyluuk
        @chubsta maybe you could use an external usb stick to store your data. With this you can syncronize your sd card with a usb stick of your choice and another advantage is that you have the system separated from your data 🙂
        https://github.com/recalbox/recalbox-os/wiki/Use-an-external-usb-storage-device-on-recalbox-(EN)
