    Solved config
    config
    4553
    • Edvis
      Edvis last edited by
      Hi, can I edit the config through the local network?
      • ian57
        ian57 Staff last edited by
        @Эдвис-Фатходинов yes, just type the IP address of the recalbox in a browser... you can edit recalbox.conf
        for config.txt you need to connect via ssh or put the SD card in erader in another computer
        Edvis 2 Replies Last reply Reply Quote 1
        • Edvis
          Edvis @ian57 last edited by
          @ian57 said in config:
          SSH
          Tell me please how to connect through SSH? And if you connect sd to your computer, what is the path to the config.txt file?
          • Edvis
            @ian57
            I installed the PuTTy program for SSH connection, tell me please the host name (ip address)?
              Could you start by read the manual & wiki please.
              https://github.com/recalbox/recalbox-os/wiki/Manual-(EN)
              https://github.com/recalbox/recalbox-os/wiki/Mini-How-To-(EN)
              Edvis 1 Reply Last reply Reply Quote 1
              • Edvis
                Edvis @rockaddicted last edited by
                @rockaddicted
                I did not find there how to edit the config.txt file over the local network
                  paradadf Staff @Edvis last edited by
                  @Эдвис-Фатходинов
                  Keywords: WinSCP + remount as writable
                  Try using the search function of the forum and google, please.
                  • Edvis
                    Edvis @paradadf last edited by
                    @paradadf
                    I got to editing the config.txt file using the PuTTy program via SSH connection. Please tell me how to save the settings after editing?
                      @Эдвис-Фатходинов google it.
                      • Edvis
                        @paradadf In google all the articles on this topic in English, I can not help but understand, I do not know English and I can not find anything I can not. Now I'm writing an interpreter. I need to know which buttons to press to save?
                          @Эдвис-Фатходинов
                          https://github.com/recalbox/recalbox-os/wiki/Make-a-partition-writable-(EN)
                          CTRL+X, Y, ENTER after you edit anything with nano.
                          • Edvis
                            @paradadf Thank you very much =)))
                            • Edvis
                              @paradadf Hello, I edited the config file and put the video through 3.5 pixels on the CRT TV, but the video on the sides goes outside the TV screen, help please how to fix it? I tried to enter "overscreen", but it does not help, in games the image still goes beyond the edges of the screen.
                                @Эдвис-Фатходинов this topic is about how to edit the config, not about video settings. Open a new one if you need help. But you are completely forgetting about reading the wiki!!!
                                For example:
                                https://github.com/recalbox/recalbox-os/wiki/Video-configuration-detailled-(EN)
                                I'm closing this thread.
