    Free space not available
    free space available
    • yan74s
      yan74s last edited by
      Hello
      I have transfered Sets of Roms from an USB stick to my SD card. (created the /share/ folder structure on my stick to simplify the copy by "cp -rv /media/usb0/share /recalbox/" )
      But there where too much data on my USB stick and my SD card were filled at 100% (last files were writed with the size of 0 octet)
      After that, under windows, with access to my raspberry trough my network, I deleted all the 0 octet files and some other big files to free some space .
      But I have this problem :
      I made free space (I can see free space with PartionGuru) but if I try to copy files Windows says that the folder is still full.
      What happens under command line : (I wrote only the line with the problem, the others are ok)
      df -h
      Filesystem ....................Size...............Used..............Avail...............Use%...............Mounted on
      /dev/mmcblk0p8...........55G..............50G..................0...................100%............./recalbox/share
      As you can see see : I have 5G of free space but it says 100% use and 0 available
      (Before I deleted some files trough windows, I had 0G of free space)
      Is there a way to refresh the memory ? Or a way to get back my free space ?
      Thanks in advance for your help !!
      • gzubsc
        gzubsc last edited by gzubsc
        I will not helping a lot but I have same kind of issue:
        df -h
        Filesystem Size Used Available Use% Mounted on
        /dev/mmcblk0p3 114.9G 110.7G 0 100% /recalbox/share
        It seems that it's happening when I remove files from WinSCP or Putty for exemple (I find it easier when I have to remove a directory like in Dosbox emulator)
        I have searched on the web for refreshing this lost free space but everithing I can find is tutorials on how to find the dummy/trash/lost files...
        Not a big deal because I can still copying games on the card, but updates are crashing because of the "lack" of free space 😞
          This reminds me something, but i just can't remember what was the origin of the problem ... Any trashbin folder or lost files or something like that ?
          • nurf
            nurf last edited by nurf
            I met the worries. I solved it. I'm posting this to help someone: It's related to the super user placeholder. By default on ext4, it is 5%. To recover this space, you must mount the key on a linux distribution and use tune2fs on the "Share" partition. Like this: tune2fs -m 0 / dev / sdXY. You will recover the few remaining GB.
