    RemotePI and Recalbox 4.0.2 losing scrape data
    remotepi recalbox 4.0.2 loosing scrape
    • stet
      stet last edited by stet
      Hello.
      I have a RemotePi installed and am currently at Recalbox 4.0.2 (auto updated from 4.0 to 4.0.1 and now to 4.0.2) on a Raspberry PI 3. I've noticed then after shutting down with the RemotePi that the next time I power on some random systems will have lost all of the games scrape data (typically NES or GBA, sometimes MegaDrive). I don't remember having this problem with 4.0. I went into the recalbox.conf to make sure that I have the correct entry un commented but see this instead of what used to be there:
      ------------ A - System Options -----------
      Uncomment the system.power.switch you use
      system.power.switch=REMOTEPIBOARD_2005 # http://www.msldigital.com/pages/suppo$
      All the same line, all uncommented. This is not what I remember having there when I originally set up my RemotePi with 4.0. Could this be the problem? Is the RemotePi script not running correctly?
      Thanks!
        paradadf Staff last edited by
        The script runs correctly despite of that, see:
        https://github.com/recalbox/recalbox-os/issues/968
        • stet
          stet last edited by
          Hmm. If the shutdown script is running correctly then how can I prevent it from deleting scrape data? It seems to me that it might be shutting power off too quickly.
            Ok, I only talked about the multiple lines, not about if the script is shutting down properly.
            I have no idea baout that.
            101.4k
