    Solved Mame samples - newbie with issues! Also, is Daphne possible?
    mame samples issues daphne possible
    • chubsta
      chubsta last edited by
      I have searched as much as i can and can only find threads stating that it was being worked on - in case i have missed something obvious (which is quite possible as the forum behaves very strangely on my mac and doesn't scroll properly) is it possible to add the mame sound samples for use with recalbox, and if so what is the file structure?
      Secondly, I love laserdisc games and am aware that Daphne can be played using a different bit of software on the Pi, but is it in the future for Recalbox?
      Thanks for any advice, loving the ease of use of this software, absolutely great!
        Hello
        For mame sample read readme file in /recalbox/share/roms/mame
        Sorry in french but check url
        http://mamedl.esy.es/static8/mame
        chubsta 1 Reply Last reply Reply Quote 1
        • chubsta
          chubsta @acris last edited by
          @acris
          Hi, thanks very much for the quick reply, all samples now working great - i guess i am in just too much of a hurry to get everything up and running which means i keep missing stuff!
