    Moonlight Pairing
    moonlight pairing
    • jor2404
      jor2404 last edited by
      Re: Moonlight not pairing
      I am having the same problem, Whe I try to pair it seems to freeze on Searching for server...
      I run avahi-browse -prt "_nvstream._tcp" and I didn´t get nothing.
      On my pc in Geforce Experience seems GameStreams seems to be ok
      Could you guide me in the steps to take to solve it?
      • idarius
        idarius last edited by
        have you read this ?
        https://github.com/recalbox/recalbox-os/wiki/Setup-moonlight-(EN)
        and this part :
        Optional step if you have other compatible moonlight PCs :
        Edit /recalbox/share/sysem/configs/moonlight/moonlight.conf
        remove the # in front of #address =
        Add your IP. Ex : address = 192.168.0.12
        Save your file
          Substring @jor2404 last edited by
          @jor2404 do yuo have an account set on your GFE ? What GFE version do you have ?
          • jor2404
            I solved that part the problem was that GFE wasn´t be activated to stream the games so finally I paired it.
            Now the problem is that I can see moonlight logo in raspberry and also the games, but if I try to start a game from moonligth on my raspberry it doesn´t start in my pc so the only thing I see on my raspberry is the Recalbox logo with the entire screen in black
              @jor2404 Recalbox 4.0 is compatible with GFE3.1 max, you should downgrade. Recalbox 4.1 (which is currently in public testing) is good to go with the current version of GFE
              100.8k
