    RECALBOX on NOOBS/RASPIAN to run simultaneously other services?
    recalbox noobsraspian run simultaneously services
    2481
    • StefanMe
      StefanMe last edited by
      Hello!
      Is there any change to install the RECALBOX on an NORMAL NOOBs/Raspian Image? I have to run some other SUDO Stuff (Homebridge/Ambilight ect.) on the Pi also...
      best Regards! Stefan
        Substring @StefanMe last edited by
        @StefanMe Hi
        Please read the wiki, there is an explanation on how to dual boot raspbian+recalbox. But both systems are distinct, on seperate partitions.
        • StefanMe
          Thx for the reply, but this is exatly what i dont want. I need both systems simultaneously running at the same time. Or is it possible to add an pi user and install node ect. on the RECALBOX partion? Has anyone done that yet?
          DjLeChuck Substring 2 Replies Last reply Reply Quote 0
          • DjLeChuck
            DjLeChuck @StefanMe last edited by DjLeChuck
            @StefanMe No it's not. Recalbox is an independant OS, not a software launched on an existing OS.
            • StefanMe
              Its a pity! But still great work!! Works nicely out of the box! I think i ll buy another pi and donate the project after i finished!
                @StefanMe Impossibru !!!!!
                101.4k
