    C64 problem on 4.1.0 unstable
    Emulator Arcade/PC/Console
    c64 4.1.0 unstable
    6
    19
    9286
    • treacle
      treacle last edited by
      C64 not working at all for me... I see my D64 files in EmulationStation, but when I try to launch one, I get a black screen and end up back in ES.
      any ideas?
        Substring @treacle last edited by
        @treacle should work on the second launch. The C64 was an external contribution, relies on SDL1, i didn't have time yet to b*mp it to SDL2
        What you should do : kill the vice process with SSH, then try again, i think it works
        treacle Stonejackit 2 Replies Last reply Reply Quote 0
        • treacle
          treacle @Substring last edited by
          @Substring Thanks, will try that later. have several other issues with the current unstable build. Is there a thread where they can all be posted?
            @treacle I should write one
            • Stonejackit
              Stonejackit @Substring last edited by
              @Substring
              Can you explain how to do this to a n00b? Is there a chance this problem will be solved in the next update?
              Thank you!
                Substring @Stonejackit last edited by
                @Stonejackit by ssh run killall vice
                The update will cole in an uograde, no eta yet
                Stonejackit 1 Reply Last reply Reply Quote 0
                • Stonejackit
                  Stonejackit @Substring last edited by Stonejackit
                  @Substring yeah, but where can i type it in? can i get a prompt while in the recalbox GUI?
                  oh, ok, i just learned from a collegue what SSH is. Thanks a lot!
                    Substring @Stonejackit last edited by Substring
                    @Stonejackit https://github.com/recalbox/recalbox-os/wiki/Root-access-on-terminal-(EN)
                    Download putty, no need to specify an IP, just type recalbox
                    login : root
                    password : recalboxroot
                    (don't be afraid, no ***** when typing the password)
                    Stonejackit 1 Reply Last reply Reply Quote 1
                    • Stonejackit
                      @Substring thanks substring! 🙂
                        @substring Vice is no more built for the moment. No binary is included in current 4.1 version.
                        • Stonejackit
                          Stonejackit @rockaddicted last edited by
                          @rockaddicted So does that mean, there's no C64 support right now? This was actually the reason i upgraded to 4.1 in the first place. 😞 can you estimate when it's gonna be reimplimented?
                          thank you.
                            @Stonejackit re-enabling vice shouldn't be "that" hard, but :
                            • the integration is not good yet (half done external contribution ...)
                            • there are mor urgent matters to solve before
                            But don't worry, i could start it on my dev recalbox. Should take a few days/week to make it available
                            Stonejackit RustyMG 2 Replies Last reply Reply Quote 1
                            • Stonejackit
                              @Substring thanx for clarifying! i'll be patient then ^^
                              • RustyMG
                                RustyMG last edited by
                                Hi,
                                Just to see if there has been any progress with Vice? 🙂
                                Sinclair ZX Spectrum 48k "dead flesh" keyboard, Commodore 64, Amiga A500, Amiga A1200, CD32, PC Engine, PS1, PS2, PSP, Nintendo DS, Dreamcast, Wii, XBox 360, Xbox One-X, Pi2, Pi3, Pi4 owner, ARRM contributor ( http://jujuvincebros.fr/wiki/arrm/doku.php ).
                                  rockaddicted @RustyMG last edited by
                                  @RustyMG nope
                                  • RustyMG
                                    RustyMG @Substring last edited by
                                    @Substring @rockaddicted What about now, lol ?
                                    In all seriousness though, any development in the C64 emulation side?
                                    • Hoduken
                                      Hoduken last edited by
                                      There is a VICE libretro core available, no problem at all to compile it to recalbox supported architectures (rpi, x86/x64, odroid).
                                        The libretro core is the best option I guess
                                          rockaddicted @Hoduken last edited by
                                          @Hoduken yep it is in the to do list, but can't be everywhere.
                                          101.0k
