    A question about Recalbox updates and es_Systems config file
    recalbox updates essystems config file
    • goggy
      goggy last edited by
      Hi,
      Every time i do a Recalbox update, its changes the es_systems config file back to default. It can be slightly annoying as i have added emulator themes for emulators such as Super Famicom, Cave, Capcom and TG16 to the Frontend.
      I'm just wondering, does this file need to be changed back to default every time there is an update to Recalbox, can it be removed from the update process?, so i don't have to keep changing the file after update, thanks in advance.
        paradadf Staff last edited by
        Nope, it can't.
