    can i change GPIO pin layout ?
    GamePad/GPIO/USB encoder
    gpio pin layout
    • Alex Na
      Alex Na last edited by
      i wanted to directly mount the perf board with buttons on the pi zero, but pin layout didnt allow me to.
      so i used some pins for controller 1 and 2 together .
      now i have a problem 😄
      in the recalbox.conf i can just enable and disable the gpio input,
      i cant make custom key bindings.
      is it possible ? can anyone tell me how to do it ?
        Substring @Alex Na last edited by
        @Alex-Na There is a version of the kernel module that supports reconfiguring GPIO pins functionnality. But I'm afraid you should compile it by yourself or ask @ian57
