    Solved RB8-64 Controller - Nintendo 64 Bluetooth Controller
    GamePad/GPIO/USB encoder
    rb8-64
    5922
    • Maxime Allard-Valade
      Maxime Allard-Valade last edited by Maxime Allard-Valade
      Hi,
      What about Retro-Bit 8Bitdo Nintendo 64 controller.
      http://images.nintendolife.com/news/2016/12/hardware_review_retrobit_x_8bitdo_rb8-64_n64_bluetooth_controller/attachment/0/original.jpg
      Will be compatible?
      Someone test it?
      Thanx
        Finally, I buyed these controllers and it's working fine. 😄
        You pair one of your bluetooth controllers.
        You can edit buttons in Emustation for navigation through Emustation.
        To get proper buttons when you play, you need to modify InputAutoCfg.ini.
        \\RECALBOX\share\system\configs\mupen64
        Here's my config for my RB8-64 controllers.
        ;Nes30 Pro Controller
        [Bluetooth Wireless Controller   ]
        plugged = True
        plugin = 2
        mouse = False
        AnalogDeadzone = 4096,4096
        AnalogPeak = 32768,32768
        DPad R = hat(0 Right)
        DPad L = hat(0 Left)
        DPad D = hat(0 Down)
        DPad U = hat(0 Up)
        Start = button(11)
        Z Trig = button(10)
        B Button = button(1)
        A Button = button(0)
        C Button R = button(8)
        C Button L = button(4)
        C Button D = button(3)
        C Button U = button(9)
        R Trig = button(7)
        L Trig = button(6)
        Mempak switch =
        Rumblepak switch =
        X Axis = axis(0-,0+)
        Y Axis = axis(1-,1+)
        Couch gaming is so confortable now.
          Substring @Maxime Allard-Valade last edited by
          @Maxime-Allard-Valade Hey thanks for the feedback 🙂 How did you manage the hotkey ?
          Maxime Allard-Valade 1 Reply Last reply Reply Quote 0
            Maxime Allard-Valade @Substring last edited by Maxime Allard-Valade
            @Substring I'll check it tonight, I know you need to change it in recalbox.conf, something like that. I'll give you an answer soon. 🙂
              Little fix**
              ;RB8-64 Controller
              plugged = True
              plugin = 2
              mouse = False
              DPad U = hat(0 Up)
              Start = button(11)
              Z Trig = button(10)
              C Button R = button(9)
              C Button U = button(8)
              R Trig = button(7)
              L Trig = button(6)
              Mempak switch =
              Rumblepak switch =
              For the hotkey, you need to modify mupen64plus.cfg.
              Section [CoreEvents]
              # Joystick event string for stopping the emulator
              Joy Mapping Stop = "J0B6/B7"
              Joy 1 Button 6 + Button 7
              Player 1 presses Left trigger + Right trigger to leave the emulator.
              It's the only one I need, and it's the only combinaison I found that's working.
              References here
                paradadf Staff last edited by
                I'd like to point out that, apparently, the NES30 Pro and this controller have the exact same device name (bluetooth wireless controller with three spaces at the end).
                But the NES30 Pro starting at version 1.72 beta 0 (newest at the moment) finally changed its name to, I believe, Nes30 Pro Controller (or similar). So if anyone happens to have both, it is just a matter of upgrading the firmware.
