    Solved Yoshis Island SNES Controller Problem
    Emulator Arcade/PC/Console
    yoshis island snes
    6
    8
    6306
    • levendis32
      levendis32 Translator Banned last edited by
      Hello , I try to play Yoshi Island but I get a message that game can play only with a normal controller.
      What can I do ?
      • DjLeChuck
        DjLeChuck last edited by
        Hi,
        As say in this topic: https://forum.recalbox.com/topic/3764/controllerproblem-super-mario-world-2-yoshi-s-island/3
        • Edit game data
        • Emulator -> libretro
        • Core -> pocketsnes
        And it will be ok!
        levendis32 1 Reply Last reply Reply Quote 0
          Topic move in good section
          • levendis32
            levendis32 Translator Banned @DjLeChuck last edited by levendis32
            @DjLeChuck
            I dont know what are you talking about ,
            the only folder to edit is from my Computer in the Share folder where I drag roms to play them on Recalbox but I dont know where to
            Edit game data
            Core -> pocketsnes ? ? ?
            thanx anyway for the respond
            Maxime Allard-Valade 1 Reply Last reply Reply Quote 0
            • Maxime Allard-Valade
              Maxime Allard-Valade @levendis32 last edited by Maxime Allard-Valade
              @levendis32 When you select the game into Recalbox, press Space from your keyboard, and you will be able to edit some options specially for this game. You just need to try/change the core.
              • levendis32
                levendis32 Translator Banned @Maxime Allard-Valade last edited by
                @Maxime-Allard-Valade I will try it when I get a keyboard right now I m playing on a ps4 controller. I also noticed that I cannot save a game on Super Metroid
                  voljega Banned @levendis32 last edited by
                  @levendis32 you don't need a keyboard, go on the game and press select with your controller
                  • sergioad
                    sergioad last edited by
                    I use that game, what you will need to fix that is to go to the main RetroArch's in game menu, go to the quick menu, controller and there you will need to put the 2P's gamepad as a normal controller instead of multitab, doing that you will solve the issue
                    101.4k
