    Solved NES30Pro not detected, won't pair
    GamePad/GPIO/USB encoder
    nes30pro detected wont pair
    2812
    • hunterln
      hunterln last edited by
      Fresh install of recalbox 4.0.0b on raspberry pi 3.
      When trying to pair bluetooth controller (8bitdo NES30 Pro) it never can find any devices. Instantly fails.
      I have tried latest NES30 Pro firmware 1.72 as well as older 1.69.
      Same problem. Checked config file to make sure bluetooth controller support is enabled.
      According to this it should work:
      https://github.com/recalbox/recalbox-os/wiki/8bitdo-on-recalbox-(EN)
      Looking for some help, thanks in advance.
        paradadf Staff last edited by
        You need a bluetooth dongle, as the internal bluetooth of the RPi3 will be available not before 4.1.
        hunterln 1 Reply Last reply Reply Quote 0
        • hunterln
          hunterln @paradadf last edited by
          @paradadf Thank you, I suspected but the list of supported controllers I referenced isnt very clear on the need for a dongle. I'll look for the list of supported peripherals to see what dongles are supported...but does anyone have any suggestions on a specific dongle they've used with NES30 Pro or SFC30Pro? I have one of each and I will have to get dongles for both so I can do 2 player.
          Thank you!
            paradadf Staff @hunterln last edited by
            @hunterln you can use just one bluetooth dongle for multiple controllers.
            • hunterln
              @paradadf perfect, thanks! BTW, do you know anything about expected release for 4.1?
                @hunterln only God knows.
                Recalbox is an entirely volunteer job, so a beta will be release when developers bring it to a state stable enough for general use. Before that it doesn't make any sense, because users would be complaining about stuff not working as expected. It is that simple.
