    LG flatron blank screen
    flatron blank
    3925
    • quills
      quills last edited by
      hi i have the an old LG montor Flatron l204wt. i am able to run retropie and other emulators, but recalbox loads up and i i get is blank screen. i get the splash screen with the sd card. then just blank.
      Thank you
        hello
        did you read this tutorial ?
        https://github.com/recalbox/recalbox-os/wiki/Video-configuration-detailled-(EN)
        quills 1 Reply Last reply Reply Quote 0
        • quills
          quills @acris last edited by
          @acris thank you so much, some how i miss that part in the wiki thank you for pointing it out to me sorry about that, some how i missed it. thank you, i hope i can get it to work now
            Substring @quills last edited by
            @quills I'm the one who wwrote the wiki acris mentionned, feel free to ask if you ever have any question
            • quills
              quills last edited by quills
              ok went in and looked at all the setting so far so good till this happen
              https://flic.kr/p/RvjEEP if you look at the pic you will see running it via hdmi to dvi and ruing native what my monitor wants all other resolution looks out of wack and stretched out . any ideas? or am i going to have to use retropie (works flawless on it).
                @quills please make a pastebin of your config.txt and your recalbox.conf
                • quills
                  quills last edited by Substring
                  ****ony part i changed in the recalbox.conf
                  ## (string)
                  global.videomode=default
                  btw did the same thing with i set it for dmt 57
                  • quills
                    quills last edited by acris
                    and config.txt
                    config.txt
                    # uncomment if you get no picture on HDMI for a default "safe" mode
                    hdmi_safe=1
                    disable_overscan=1
                    # uncomment to force a specific HDMI mode (this will force VGA)
                    hdmi_group=2
                    hdmi_mode=57
                    # comment to get jack audio
                    hdmi_drive=2
                    config_hdmi_boost=0
                    # force hdmi while the tv can take time before sending the signal on the hdmi o$
                    hdmi_force_hotplug=1
                    # uncomment for composite PAL
                    #sdtv_mode=2
                    # uncomment for lirc-rpi
                    #dtoverlay=lirc-rpi
                    # if you plug your tv at the same time as your rpi and that the rpi switches fr$
                    boot_delay=3
                    # uncomment if you don't want the rainbow at startup
                    disable_splash=1
                    # Overclock
                    gpu_mem_256=128
                    gpu_mem_512=256
                    gpu_mem_1024=512
                    avoid_safe_mode=1
                    kernel=zImage
                    # NOOBS Auto-generated Settings:
                      @quills i'd rather have your full recalbox.conf as i want to see it all 🙂
                        and you said you're using HDMI2DVI ? Have you read https://github.com/recalbox/recalbox-os/wiki/Connect-your-recalbox-to-a-DVI-screen-(EN) ? because i see you still have hdmi_drive=2
                        • quills
                          here the recalbox.conf and btw keeping it or removing it makes no different. but i do what to thank you for the help. i really do mean it .
                          # System Variable
                          system.manager.enabled=1
                          ## Recalbox API (REST)
                          system.api.enabled=0
                          ## EmulationStation menu style
                          ## default -> default all options menu
                          ## none -> no menu except the game search menu
                          ## bartop -> less menu, only needed for bartops
                          system.es.menu=default
                          ## Emulator special keys
                          kodi.enabled=1
                          ## Start kodi at launch (0,1)
                          kodi.atstartup=0
                          kodi.xbutton=1
                          ;kodi.network.waittime=10
                          ## Set system hostname
                          system.hostname=RECALBOX
                          ## Activate wifi (0,1)
                          wifi.enabled=1
                          ## Wifi SSID (string)
                          wifi.ssid=Get off my Bandwith
                          ## Wifi KEY (string)
                          wifi.key=
                          ## Samba share
                          system.samba.enabled=1
                          ### Virtual Gamepads
                          ### SSH
                          system.ssh.enabled=1
                          audio.device=auto
                          ## Set system volume (0..100)
                          audio.volume=94
                          audio.bgmusic=0
                          controllers.ps3.enabled=1
                          ## Choose an driver between official, shanwan and gasia if you have dualshock clones (official,shanwan,gasia)
                          controllers.xboxdrv.enabled=0
                          ## GPIO Controllers
                          controllers.gpio.enabled=1
                          controllers.gpio.args=map=1
                          ## DB9 Controllers
                          controllers.db9.enabled=0
                          ## db9 arguments
                          controllers.db9.args=map=1
                          ## Gamecon controllers
                          controllers.gamecon.enabled=0
                          ## gamecon_args
                          controllers.xarcade.enabled=1
                          system.language=en_US
                          ## Set you local time
                          ;system.timezone=Europe/Paris
                          updates.enabled=1
                          # default : stable ; set to beta to get the next version currently being tested. set to unstable at your own risk to get the development ve$
                          updates.type=stable
                          ## (string)
                          ## Shader set
                          ## (none, retro, scanlines)
                          global.shaderset=none
                          global.integerscale=0
                          global.shaders=
                          global.ratio=16/9
                          global.smooth=1
                          global.rewind=1
                          global.autosave=0
                          global.retroachievements=0
                          global.inputdriver=auto
                          ## Here is the snes example
                          ;snes.videomode=CEA 4 HDMI
                          snes.core=snes9x_next
                          ;snes.ratio=16/9
                          ;snes.smooth=0
                          ;snes.rewind=1
                          ;snes.autosave=0
                          ;snes.emulator=libretro
                          ;snes.integerscale=0
                          ;snes.smooth=0
                          ;snes.rewind=1
                          ;snes.autosave=0
                          ## Default cores for RPi3
                          gba.core=mgba
                          mame.core=mame078
                          nes.core=fceunext
                          ## NeoGeo emulator
                          neogeo.emulator=libretro
                          ## If you set libretro as neogeo.emulator, the line below sets the retroarch core (fba,imame4all)
                          neogeo.core=fba
                          n64.videomode=DMT 4 HDMI
                          # n64.videomode=default
