    Solved Issue with sound on DS4 via Bluetooth
    GamePad/GPIO/USB encoder
    issue sound ds4 bluetooth
    4054
    • gotogooch
      gotogooch last edited by
      Hey, all.
      So I've been using a DS4 on a Pi3 via the Sony proprietary Bluetooth dongle and works great. However, if I turn my Pi off and leave the dongle plugged in, the next time I turn it on there is no sound. I then plugged headphones into my DS4 and realized the Bluetooth dongle is high-jacking the audio on startup. I am not sure if this can be fixed within Recalbox or if I have to fix it on the Sony end somehow.
      Has anyone else ever dealt with this? Any ideas? Please and thanks.
        plug your dongle post boot, or blacklist your DS4 sound module
        gotogooch 1 Reply Last reply Reply Quote 1
        • gotogooch
          gotogooch @rockaddicted last edited by
          @rockaddicted Thank you for the reply. Can you please point me in the right direction on how to blacklist the sound module on my DS4?
          • gotogooch
            Alright, I think I may have it. I'll try this out tonight:
            Connect in ssh via putty
            Mount partition : mount -o remount,rw /
            Edit this file: nano /etc/modprobe.d/blacklist.conf
            Add this line: blacklist snd-usb-audio
            Save & reboot
            Sound about right?
              Substring @gotogooch last edited by
              @gotogooch yep, thats looks just right
              • gotogooch
                gotogooch @Substring last edited by
                @Substring Yep, that did it! Thanks so much!
                  Move topic in right category.
                    rockaddicted last edited by rockaddicted
                    Great, can you open an issue on github please ? With problem + fix ?
                    gotogooch 1 Reply Last reply Reply Quote 0
                    • gotogooch
                      @rockaddicted I think I did so correctly? https://github.com/recalbox/recalbox-os/issues/1177
