    Possible to switch Kodi installs?
    switch kodi installs
    • james-lord
      james-lord last edited by
      If I wanted to swap Kodi for (say) OSMC or openelec etc. - is it as simple as just swapping the .kodi directories? If not can it be done, and what else would need to be added / changed?
      • nickdj
        nickdj last edited by
        This is an interesting question. If you don't mind me asking, why did you want to change it? Is there something not working?
        RPi 2 Not overclocked Edimax EW-7811UN LogiLink BT0007A USB bluetooth V2.1 PS3 Controller RecalBox v3.2.8
        • james-lord
          No, there's nothing not working, it was more of an "is it possible" ALSO being able to "drop in" one of the existing build would save having to support both the emulator and the kodi and would mean they could be updated independantly
          • digitaLumberjack
            Hello, you could if you want and you are brave enough to compile the system with your own packages 😉 https://github.com/digitalLumberjack/recalbox-os/wiki/Compilation-%26-Modifications-(EN)
