    Unsolved Keyboard and WLAN works, Gamepad not, vice versa with another usb hub?!
    GamePad/GPIO/USB encoder
    keyboard wlan gamepad vice versa
    • ChristianK
      ChristianK last edited by
      Hi Recalbox-Community,
      I have bought the following 4-Port OTG-USB-Hub and connect it to my Raspberry Pi Zero (v1.3).
      The keyboard and wlan stick works, but the Buffalo Classic USB Gamepad will not be detected. 😕
      Okay, so I bought another 4-Port USB-Hub (this time a Speedlink SL-7416-SWT with GL850G chip).
      Now the Gamepad is working, but keyboard and wlan stick are not detected. WTF!? 0o
      This must be a bad joke! I'm really annoyed! 😞
      What I am doing wrong? And how can I fix it?
      BTW: I am using recalboxOS 4.0.0 (final).
      Thanks & best regards,
      Chris
      • ChristianK
        I have testet two more USB-Hubs with GL850G chip. Then I found the problem!
        It was not the incompatibility with the chip, it was the power supply!
        A power supply with 2A or better 2.5A or 3A is needed! OMG 😜
          Don't expect a pi0 to supply enough power for that many devices on USB ...
