    Problem when openning the system settings
    openning settings
    • nubirro
      nubirro last edited by
      I started in the recalbox world with a single 4gb Sd card (i'll buy other soon). Everything was fine about the instalation. The problem is that I need to change the storage (to put New ROM files) in the system settings but it doesnt open. Just a Black image or the version of my recalbox appear when I click on it.
      What should I do? Maybe is my small Sd card? Does exist another way to put New ROM files?
      Thanks!
      • ian57
        ian57 Staff last edited by
        The SD card is too small... and ES crashes with a floating point error due to a divide by 0 in the Share partition sire computing.
        Try with a 8GB , it should work.
        this will be fixed in the future https://github.com/recalbox/recalbox-emulationstation/pull/170
