    GPIO not working, Dreamcast emulator recalbox 4.1
    Emulator Arcade/PC/Console
    gpio dreamcast recalbox 4.1
    4354
    • LeSoquiaque
      LeSoquiaque last edited by
      Hello,
      I tested today guilty gear on dreamcast emulator using recalbox v4.1. USB controller a Bluetooth PS4 controller work ok. But if I use gpio no button or stick is working.
      GPIO works fine in MAME and FBA libreto
      Thx
        Substring @LeSoquiaque last edited by
        @LeSoquiaque hi
        Maybe because the game can't be played with a dpad ? I didn't try with gpio, but the ~/configs/reicast/emu.cfg should be filled
        • LeSoquiaque
          Hi,
          This is the information from files,
          emu.cfg
          [input]
          evdev_device_id_1 = 0
          evdev_device_id_2 = 1
          evdev_device_id_3 = -1
          evdev_device_id_4 = -1
          evdev_mapping_1 = /recalbox/share/system/configs/reicast/controllerP1.cfg
          evdev_mapping_2 = /recalbox/share/system/configs/reicast/controllerP2.cfg
          joystick_device_id = -1
          controllerP2.cfg
          [compat]
          btn_trigger_left = None
          btn_trigger_right = None
          [emulator]
          mapping_name = GPIO Controller 1
          btn_escape = None
          [dreamcast]
          btn_b = None
          btn_a = None
          btn_x = None
          axis_y = None
          btn_start = None
          btn_y = None
          axis_x = None
          Thx
          • LeSoquiaque
            I change my sdcard with fresh 4.1 installation, only gpio and all games work ok in dreamcast. Any idea what happened?
            Substring Carlos Eduardo Valcamonico 2 Replies Last reply Reply Quote 0
              @LeSoquiaque no idea, bad compilation ? Wrong packages ? Someone who is not used to buildroot and Recalbox can make mistakes on rebuilding
              • LeSoquiaque
                LeSoquiaque last edited by LeSoquiaque
                @Substring the image I use in both cards is the same. Anyway problem solved, than you.
                • Carlos Eduardo Valcamonico
                  Carlos Eduardo Valcamonico @LeSoquiaque last edited by
                  @LeSoquiaque ,
                  Sorry for my stupid English, I did not quite understand, you said that when reinstalling everything worked, is that it? I just installed and found problem in 2 emulators PSP and Dreamcast, in the PSP does not move down and also to the right and no button quits the emulator, In dreamcast I can move sideways but no button works, impossible to continue in the other Emulators everything works perfectly, I using the PS3 wireless controls also works normal on PSP and Dreamcast, do I need to reinstall the package again? Thank you ....
                  100.8k
