    Solved scraper.exe obtains images but not gamelist
    scraper.exe obtains gamelist
    2942
    • disorder
      disorder last edited by
      I ran scraper.exe last night using the Wiki guide. I woke up this morning to a folder full of game images but the gamelist.xml file is incomplete. It stops at the first game not found and doesn't keep going after that. Has anyone else experienced this?
        paradadf Staff last edited by
        Which wiki? This one?
        https://github.com/recalbox/recalbox-os/wiki/Scrape-your-games-with-your-PC-(EN)
        On what OS?
        • disorder
          Yes, that wiki and on Windows 7.
            paradadf Staff last edited by paradadf
            Did you read the part where it says it is outdated? 😉
            • disorder
              I missed that 😉 I'm excited and working too fast. Does scraper.exe work correctly when used with your batch script?
                Hopefully it does! 😄
                It should, I've tested it a lot and it works very well.
                • disorder
                  Worked well, thank you.
                  101.4k
