    Live TV with Kodi not possible?
    MediaCenter & Dualboot
    live kodi possible
    • jipido
      jipido last edited by
      Hi everybody,
      i am super happy with my recalbox, but now i have a problem with the installed kodi. When i want to view my new m3u, which definitely works in the vlc-player, i use the IPTV Simple Client and see all of the channel, but when i click on the channel, he says "working" and go back to to channel list, without opening the channel.
      Is it possible to view live tv with the recalbox? Maybe it does not work because of a lack of ram or do i have to make a different configuration? Internet connection is there. The YouTube plugin does work.
      Greetings!
        paradadf Staff last edited by
        You are probably not configuring the playlist properly. The embed Kodi in recalbox is standard. Have you tried setting up the list on Kodi for Windows? If not, give it a try and you'll see it's not a recalbox problem 😉
        • jipido
          I installed the same kodi version on my firetv stick and everything is working, when i do it the same way. The playlist is not the problem. 😞
          Do i have any chance to see some logs, where the problem could be?
          Greetings
          Malte
