    Bluetooth paired controlers cant connect after restart or shut down
    GamePad/GPIO/USB encoder
    bluetooth paired controlers cant connect
    3669
    • messa
      messa last edited by
      Hi mates¡¡¡ i received yesterday 4 units 8bitdo Zero, i pair all them and works nice.
      the problem arrive when i restart the system or turn off the controller, they dont connect again and have to pair them again.
      ive checked in recalbox/share/bluetooth and they are registered...
      hope somebody can help me¡ thanks
        the trick so far is to turn them on BEFORE the pi. 8bitdo pads are always complicated ...
        messa 2 Replies Last reply Reply Quote 0
        • messa
          messa @Substring last edited by
          @Substring ill try it when arrive at home... I hope your trick works... Later i post the resultado. Thanks mate
          • messa
            @Substring i tried your trick, sometimes is imposible, and other times he can conect but between 7- 10 minutes after turno the system on.... Any idea???
              8bitdo pairing is a pain. I used zeros while adding the pi3 internal bt to recalbox, i've had quitensome headaches with them
              messa 1 Reply Last reply Reply Quote 0
              • messa
                @Substring i was thinking about to buy a new BT dongle because mine is not in list, but if it recognise and pair must not be a dongle problem itsn? I guess is something in the confif....What to you think to spend money on a new BT?
                  Substring @messa last edited by
                  @messa i don't think it's related to your bt dongle, but can't be sure. 8bitdo pads are a pain
                  • messa
                    @Substring i have good news, today ive been in fnac and finded Trust mini dongle for 8€, and works perfectly!!! In 10 seconds are the four controllers conected!!! Now we know that a dongle can work dont significate that cannot can have problems... Thanks for your opinions and help!!
                      @messa great news ! Do uou know which bt version it handles ? 4.0 ?
