    NFC Card Reader and Recalbox
    nfc card reader recalbox
    2609
    • creaturefactory
      creaturefactory last edited by
      Has anyone ever tried adding a NFC card reader and having Recalbox read nfc ?
      Looking to do this but everything is geared towards only Linux and Retropie solutions. I would like to stay within Recalbox and have this completed.
        Substring @creaturefactory last edited by
        @creaturefactory i remember seeing one guy trying that in the forum
        Anyway you'd need to provide much more technical information if you want some help 🙂
        • sevenx
          sevenx last edited by sevenx
          Do you write about the project from daftmike? The NESPi?
          You can to the same as he has done with RetroPie, but the Programming part is a bit different... you will need to do some researching and trying
          creaturefactory 1 Reply Last reply Reply Quote 0
          • creaturefactory
            creaturefactory @sevenx last edited by creaturefactory
            @sevenx Yes something similar but using momentary buttons. I have done some researching and nothing out there that ties it in with Recalbox. I like Recalbox and would rather stay with it instead of using Retropie exclusivley
            • sevenx
              I'm currently on a similar Project, when i got my material i will test it, how good it works with Recalbox. Maybe then i can help you more 😄
              • creaturefactory
                @sevenx Looking forward to it 🙂
