    Kodi lockup on ODroid XU4, take 2
    kodi lockup odroid xu4
    3184
    • Shockwave
      Shockwave last edited by
      This time, it's locking up on me with the CEC error, connected to HDMI port 1 of my TV, and I deleted the CEC file on my XU4 unit, and it's still having problems (I even double checked the USB drive, it's not there, same problems).
      Hardkernel Odroid XU4
      4.1.0 (Alpha 2) OS revision
      Dual Shock 3
      USB 3.0 external drive
      I submitted an issue on Github before and got it to work, went back to that closed thread to try to recreate the solution there, no dice. I'm leaving that one closed because I think it might be something else (also not ruling out user error here either).
        that darn CEC should be disabled ...
        Shockwave 1 Reply Last reply Reply Quote 0
        • Shockwave
          Shockwave @Substring last edited by
          @Substring What do you mean? Should I go into the file with a text editor and change the cec_hdmi value from "1" to "0"? or should I just delete the file altogether?
            I have no idea how cec or kodi work, even less how they work together. But i'd disable cec
            • Shockwave
              So I take it Kodi is broken until further notice and I can't use it in the alpha revisions of the OS until OpenELEC releases a revision?
              • Shockwave
                Any news on getting Kodi to work with XU4?
                  Be patient, the only one who knows how to handle that is busy irl atm
                  • Shockwave
                    More than happy to be patient. 🙂 turns off Kodi and enjoys ES in the meantime
