    Invalid Partition Table!
    invalid partition table
    3880
    • West
      West last edited by
      I am trying to install Recallbox on a new dell laptop, and no matter what I keep running into an error when booting to either the SD card, or USB that says "Invalid partition table!".
      I have tried both methods on creating the USB or SD from the link below. I have also used two different USB cards, but just one SD card. https://github.com/recalbox/recalbox-os/wiki/Installation-(EN)
      I will mention, I currently have Lakka installed on the internal 1TB hard drive of this laptop, so Im curious if that is causing an issue. However, like I said, I get this error when booting from either of the USBs or SD card.
      Any help is appreciated!
        which recalbox version are you trying to use ??? The x86 version can't boot from a hard drive yet
        • West
          West last edited by
          I was using the x86 64 to boot off a USB, based on the instruction off the link I posted before. I also get this error when using the SD boot though, again using the instruction on my last link. Thank you.
          http://recalbox.remix.free.fr/
          • thickglass
            thickglass last edited by
            I have the same problem 😞
            http://questtel.com
              You need 8Go usb key and problem is may be a hardware compatibility.
              • West
                West last edited by West
                I was trying to install on a Dell Inspiron 3558 Laptop i3-6001U with Intel HD Graphics 5500. It was a black friday deal, and I figured I could make a portable setup for Recalbox and play it on any TV. I returned that laptop and found another.
                The new laptop (HP ProBook 430 G3 (i5/HD520) which did boot from 32GB USB, but it doesn't support SD boot, which is a b*mmer. At least it booted though, so I guess this is/was some sort of hardware problem with the Dell, as stated.
