    GPIO hotkey and select button
    GamePad/GPIO/USB encoder
    gpio hotkey select button
    • NoAttitude
      NoAttitude last edited by
      I've tested out the GPIO buttons from https://github.com/recalbox/recalbox-os/wiki/GPIO-controllers-(EN) And they worked out well except for the hotkey button (can t be use ) , but instead the hotkey is tie with the "select button"
      Does this mean that the hotkey button in the gpio pin is not nessesary? Thankyou
      • stevex59
        stevex59 last edited by
        I have exactly the same behaviour.
        Have you resolved the issue since?
        • LeSoquiaque
          LeSoquiaque last edited by
          Its no necessary, you can use that pin for this link text
            Let's say that hk over select needed a hack although it does work much better in 4.0 than on 3.3
            101.4k
