    Upgrading SD card
    upgrading card
    • Bowzer Mike
      Bowzer Mike last edited by
      Hey I want to go from a 16 gig SD to a 32 gig do I just make a backup and load it onto the new card?
      • sevenx
        sevenx last edited by
        I think the Problem will bi de share Partition, it is scaled to the old SD Card, when you use an Pi, maybe raspi-config and "Expand filesystem" would help.
        But better make an Image Backup of the SD Card before
          you're both wrong The best way is to use a USB stick and forget about SD seize (unless you can't use a USB key)
          Bowzer Mike 1 Reply Last reply Reply Quote 0
          • Bowzer Mike
            Bowzer Mike @Substring last edited by
            @Substring yeah I don't have the USB space so I need to use a SC card
              Substring @Bowzer Mike last edited by
              @Bowzer-Mike then you can only backup through network unless you have Linux
