    Disable Menu Buttons in RecalGui
    GamePad/GPIO/USB encoder
    disable buttons recalgui
    • noxx
      noxx last edited by noxx
      Hello
      How can i disable the both menu buttons in the controller (Start/select)?
      I want add 3 gpio buttons for Hotkey, Settings (start) and Gamesettings (select).
      The Start and Select Buttons on the controller should only available in the Emus, not in the mainmenu.
      Is this possible?
        Hi,
        You can limit the menu in EmulationStation by editing the recalbox.conf (it's documented, i think the variable is something like system.es.menu)
        But your idea with gpio, impossible. The GPIO is a full controller by itself, you can't mix buttons from one pad over another
        • noxx
          noxx last edited by
          Really impossible?
          Thats not possible?
          Gpio buttons as controller 1
          Hotkey, Menu1, Menu2
          USB Gamepad AS controller 2
          No Hotkey
          No Select in mainmenu, only in Emus
          No Start in mainmenu, only in Emus
          USB Gamepad AS controller 3
          same AS controller 2
            have you tried at least what i suggested to disable start/select ?
            Nothing was done so that only pad 1 can control ES. And that's not something we would add.
              paradadf Staff @noxx last edited by
              @noxx said
              Really impossible?
              Thats not possible?
              Are you serious? I answered you already... Nothing is impossible if you learn how to code and make the changes yourself. Not every particular request can (and should) be implemented.
              https://forum.recalbox.com/topic/4799/gpio-taster-für-hotkey-und-menü-button/
