    Solved Mapped 2P Buttons Don't Behave Correctly
    GamePad/GPIO/USB encoder
    mapped buttons dont behave correctly
    15862
      Substring @tdelios last edited by
      @tdelios which board are you using ?
      tdelios 1 Reply Last reply Reply Quote 0
      • tdelios
        tdelios @Substring last edited by
        @Substring How can I tell? I was just told that it was a 2P xin-mo and by looking at it, it has 18 pins for each player
          @tdelios I meant pi ? odroid ? x86 ?
          • tdelios
            @Substring Raspberry Pi3
              @tdelios For the xin-mo, you should only map the first player and force it as player 1, the system will autoconfigure the P2 (both inputs and player position)
              tdelios 2 Replies Last reply Reply Quote 0
              • tdelios
                @Substring what do I set the 1Player and 2Player values on the controller setup.
                1Player = "#0 Xin-Mo" and 2Player = "Default"
                or
                1Player = "#0 Xin-Mo" and 2Player = "#1 Xin-Mo"
                • tdelios
                  tdelios @tdelios last edited by
                  @tdelios nvm.. read the previous post history on this
                  • tdelios
                    @Substring your awesome!
                    it was my mistaken to configure the buttons for both controllers.. .Once I configured only the 1 PLAYER and not both.. and then setup the controller for 1P = #0 XIN-MO and 2P = #1 XIN-MO .. then I was good to go..
                    THANKS!
                    tom
                      @tdelios i'm glad you can now enjoy your recalbox 🙂
                      • subvers
                        subvers last edited by subvers
                        @Substring maybe you can help me.
                        I have a 3H Dual arcade encoder(it's a xin-mo clone) and managed to configure player 1 and 2 but the problem is that I cannot use diagonals on the joysticks, for example down-right. I use rasberry pi with the last version of recalbox.
                          Substring @subvers last edited by
                          @subvers no hadoken possible ? Which version number is your last recalbox ? 4.0.2 or 4.1 ?
