    Upgrading dual boot images
    upgrading dual boot
    • ArthurDent
      ArthurDent last edited by
      If I use a dual boot image recalbox4.0.5b+kodi16.1 like this--> http://www.matthuisman.nz/2015/11/recalbox-kodi-dual-boot-images.html?m=1 when recalbox 4.1b will be out (or kodi17....) upgrading OS will be a pain in the ass (read: new install) or a straight OTA upgrade like the standard image? Thanks!!
      [ITA: Se installo un'immagine dual boot recalbox4.0.5b+kodi16.1 come questa--> http://www.matthuisman.nz/2015/11/recalbox-kodi-dual-boot-images.html?m=1 quando recalbox si aggiornerà alla 4.1b (o kodi alla 17.....) per aggiornare i sistemi sarà un casino totale (che varrà la pena cercare una nuova immagine..) o saranno disponibili gli aggiornamenti OTA automatici? Grazie!!]
        paradadf Staff @ArthurDent last edited by
        @ArthurDent such a questions should you write in the authors blog, not here. But yes, there will be no problem with the update. The modification there is minimal, and NOOBS allows you to install more than just recalboxOS, so don't worry.
          i can only answer for the 4.1 upgrade : it will be a regular OTA, not like the jump from 3.3 -> 4.0
          I don't think it should bother your dual boot, but you'd better get the confirmation from Matt
