    64 gb for recalbox and roms
    GamePad/GPIO/USB encoder
    recalbox roms
    • Manuel Giuseppe Trizzo
      Manuel Giuseppe Trizzo last edited by Manuel Giuseppe Trizzo
      I would like to buy a microsd 64gb,to install recalbox and all roms.
      recalbox works well with SD 64GB?
      (Samsung UHS-1 Class 10)
        Can't say we love samsungs ... most of time they raise some problems with noobs.
        If you need much space, we strongly recommend using USB keys
        64GB storage devices are a litte more complicated to format, that's the main drawback
          @subs I have problems with USB Key....
          https://forum.recalbox.com/topic/4582/i-can-not-transfer-the-games-on-usb-key/23
          • Bertille
            Bertille last edited by
            Hi,
            No problem with SD 64GB i use it on my RecalBox ;+)
            Nello Cognome 1 Reply Last reply Reply Quote 0
            • Nello Cognome
              Nello Cognome @Bertille last edited by
              @Bertille said in 64 gb for recalbox and roms:
              hello can you help me with my SD 64?
              This problem: https://forum.recalbox.com/topic/4606/new-microsd-problem-black-screen-on-startup-recalbox
