    How to create USB bootable for x86-64-bit for 4.1 (alpha)?
    create usb bootable x86-64-bit 4.1
    8
    28
    20258
      paradadf Staff @Substring last edited by
      @subs there is no need for that. You can just select *.* to see all files and choose recalbox.img.gz directly. On Windows, you usually unzip the .img.gz altogether, which isn't helpful.
      • botte
        botte last edited by
        thanks guys. It was actually due to wrong downloading of image! I was able to boot recalbox 64 bit 🙂 I unzipped the .img.gz and put it on usb key with win32diskimager. Works perfect
        • Shockwave
          Shockwave last edited by
          Another Q: how long does it take for a OS revision to transition out of alpha to beta for you? So I can download a more stable version (found some experience-killing bugs in the alpha versions for the 32-bit x86, 64-bit x86 and Odroid XU4 versions). I know these things take some time to work out (I'm also a fellow programmer as well, so I know debugging, testing, documentation, retest, etc. is all a pain in the @$$). Do you have an average time to release? (not binding, because, well, it's software, and us programmers know software does slip due to unforeseen circumstances).
            Substring @Shockwave last edited by
            @Shockwave have you reported these bugs ? All the platforms you are mentionning are just like newborns. Despite the great work from susan33, it will take some time to reach a mature version.
            Concerning the XU4, the job is done, i didn't find much to say abt it, it works really good. Please either fill an issue on github or open a new topic so that you can name this experience-killing bugs. Unless you've already done so ?
            • Shockwave
              I'll gladly do some more testing on the XU4. 🙂
              • Shockwave
                Right now, not reporting any bugs because I know they're really early/young on the x86 platforms, so that's why I'm not really harping on any really "mid-range" bugs right now because you've got the big ones to worry about.
                I've got one on your XU4 so I'll hop on GitHub and submit it. 🙂
                • otopba
                  otopba last edited by
                  Hello!
                  Downloaded Recalbox, wrote on a flash drive.
                  On the computer everything is loaded, everything works.
                  I decided to move to the ancient laptop.
                  But the trouble is that there is no EFI in it. Accordingly does not see Recalbox. A flash drive on boot sees other boot disks load (like HirenBootCD)
                  But batosera does not want.
                  No one came across? How to download it without UEFI mode? Google, unfortunately, did not help.
                  I also tried LAKKA. Also does not see it on the flash drive.
                  I detached the HDD, connected it via USB to another computer, wrote down Recalbox using Win32 imager. Does not work.
                  EasyBSD does not work, there is no UEFI.
                  I do not know what to do.
                  • abunille
                    abunille @otopba last edited by
                    @otopba said in How to create USB bootable for x86-64-bit for 4.1 (alpha)?:
                    Hi,
                    you are here in recalbox Forum and not batocera.
                    Explain your problem in the batocera Forum 😉
                    100.8k
