    Play Bluray does not work
    MediaCenter & Dualboot
    play bluray does
    • lackyluuk
      Hello community
      I ripped a BlurayDisc and then put the BDMV folder to my movie directory. Play DVDs works fine, but I cannot play Bluray movies. Is there a library missing or should Kodi can handle this Out of the box?
      Is somebody around who can play Bluray in recalboxs Kodi?
      Thanks in advance 🙂
      • Nachtgarm
        Nachtgarm last edited by Nachtgarm
        Quotes from the Kodi Forum:
        "Kodi can playback unencrypted bluray discs and bluray images. There is limited support for some bluray menus."
        I suggest converting to MKV
        [...] put the whole BDMV folder into your movie folder and let Kodi scrape the title [...]
        [...] don't start the .mts files, but start the movie from the library [...]
        but I'm not sure, if we have implemented the libbluray1. @subs? @digitaLumberjack?
        • lackyluuk
          @Nachtgarm Thanks for your answer. I did exactly this. But what I do not know for sure is, if the movie is encrypted after copying?
          And yes, this was also in my mind. Is this library installed? Not sure if I really need it.
