    Recalbox Emulation Station Theme & Emulator Change
    recalbox station theme
    6027
    • KwansuDude
      KwansuDude last edited by
      The Wiki is not the easiest to navigate for a noob.
      Could someone please provide a little easier set of instructions on:
      1. Changing the Theme of ES
      2. Changing the Order the Emulators show up on ES
      Thank you,
      KwansuDude
        paradadf Staff last edited by
        1. https://github.com/recalbox/recalbox-os/wiki/Add-emulationstation-themes-(EN)
        2. you can't
          voljega Banned @paradadf last edited by voljega
          @paradadf I may be wrong but to change the order of the emulators, I think you just have to change the order in wich they appear in es_systems.cfg
          paradadf 1 Reply Last reply Reply Quote 1
            paradadf Staff @voljega last edited by paradadf
            @voljega You must be right!
            /recalbox/share_init/system/.emulationstation/es_systems.cfg
            The file looks like this.
            @KwansuDude you'll need to remout the partition in order to edit the file using:
            mount -o remount,rw /
            The file will be overwritten after every update.
            • supernature2k
              supernature2k last edited by
              Yep but DON'T PUT FAVORITE AS FIRST
              • 8bit_astronaut
                8bit_astronaut last edited by
                Well i just edited the emulationdtation config file, accesing the sd with a program called paragon exts and changing the emulators order:
                -first all nintendos
                -segas
                -nec
                -neogeo
                -atari
                -psx
                -computers
                -mame and fba
                -ports
