    Virtual Gamepad not working correctly?
    GamePad/GPIO/USB encoder
    virtual gamepad correctly
      paradadf Staff last edited by paradadf
      I just tried the virtual gamepad and had problems with the d-pad. You usually get the button you are pressing marked, but with the d-pad I'm seeing a circle not on the spot I'm pressing. Please, it would be helpful if some people test it to see if something got disconfigured. Thanks!
      The touch zone should look like this:
      virtual_gamepad
      recalbox v4.0.0 beta 5
        Tbh, i never use it until there's a knife on my throat. The hitboxes are weird on my phone, it works pretty bad for me ...
          I don't use it either, but just today I got two persons asking me about it and telling me that it didn't work as expected.
            Let's say it works as a poltergeist would expect 😉
            • ivwshane
              ivwshane last edited by
              It works for me and has the correct zones. Having said that, it unfortunately doesn't work that well. Pressing up+ forward or up+ back rarely works. Sometimes I have to refresh the page or even exit and reopen the page.
              I'm on an iPhone 6s.
