    IPAC 2 and extra buttons (ESC etc)
    GamePad/GPIO/USB encoder
    ipac extra buttons esc etc
    • Colin Williams
      Colin Williams last edited by
      Hi,
      I'm running an iPAC2 in a custom box with Recalbox 4b5. Buttons for both players work perfectly including coin, p1&p2 buttons...
      My problems is that I can't get hotkeys, ESC, select, enter etc working...which means I have to run the box with a keyboard attached just to exit a game 😉
      Is mapping the additional buttons I've added to my controller possible? I've checked with WinIpac utility and the missing buttons are all mapped appropriately to the extra outputs on the IPAC (i.e., 1A, 1B, 2A & 2B) and if I test these, they send appropriate key presses...I just can't figure out how to get Recalbox to register them?
      Thanks for any help 🙂
        Hello
        This link can help you may be https://github.com/recalbox/recalbox-os/wiki/keyboard-encoder-configuration-(EN))
        • Colin Williams
          Thanks. That got my "ESC" key combo working 🙂
          I might just look at putting an additional IPAC2 in the cab and install the "keyboard" firmware on that so that I can connect my utility buttons directly to it.
            voljega Banned @Colin Williams last edited by
            @Colin-Williams why not use hotkey instead of esc ?
            And why the enter button ? Computer games ?
