    N64 Emulator Help
    Emulator Arcade/PC/Console
    help
    3385
    • Thedirtybaby
      Thedirtybaby last edited by
      This morning I tested out the emulator with Diddiy Kong Racing and it booted up and ran great. I set the Pi to scrape some files while I was at work and when I came home I messed with it a little and now none of the n64 roms will play. I'm using a wireless xbox 360 controller that I have the driver downloaded. Also I have changed the n64 video mode with no luck so it is back to dmt 4. Any suggestions would be greatly appreciated.
        What is the problem ? I don't recommend going above dmt 4 for performance matters
          paradadf Staff last edited by
          You downloaded a driver for your controller?
          • Thedirtybaby
            The problem is I can't figure out now why any of the roms will not play. Diddy Kong Racing worked when it was set to default emulator and plugin. Now it doesn't work when I try it as default or selecting the emulator and either of the three plugins. Basically I don't know what changed to make that system not work anymore. Also I guess download wasn't the right word, I have activated the xboxdrv driver support in the config file is what I should have said.
              did you deactivate the ps3 driver accordingly?
              • Thedirtybaby
                Thedirtybaby last edited by paradadf
                I did. Here is my config file if you don't mind looking to see if anything looks wrong.
                # System Variable
                system.manager.enabled=1
                ## Recalbox API (REST)
                system.api.enabled=0
                ## EmulationStation menu style
                ## default -> default all options menu
                ## none -> no menu except the game search menu
                ## bartop -> less menu, only needed for bartops
                system.es.menu=default
                ## Emulator special keys
                kodi.enabled=1
                ## Start kodi at launch (0,1)
                kodi.atstartup=0
                kodi.xbutton=1
                ;kodi.network.waittime=10
                ## Set system hostname
                system.hostname=RECALBOX
                ## Activate wifi (0,1)
                wifi.enabled=1
                ## Wifi SSID (string)
                wifi.ssid=
                ## Wifi KEY (string)
                wifi.key=
                ## Samba share
                system.samba.enabled=1
                ### Virtual Gamepads
                ### SSH
                system.ssh.enabled=1
                audio.device=auto
                ## Set system volume (0..100)
                audio.volume=96
                audio.bgmusic=0
                controllers.ps3.enabled=0
                ## Choose an driver between official, shanwan and gasia if you have dualshock clones (official,shanwan,gasia)
                controllers.xboxdrv.enabled=1
                controllers.xboxdrv.nbcontrols=4
                ## GPIO Controllers
                controllers.gpio.enabled=0
                controllers.gpio.args=map=1,2
                ## DB9 Controllers
                controllers.db9.enabled=0
                ## db9 arguments
                controllers.db9.args=map=1
                ## Gamecon controllers
                controllers.gamecon.enabled=0
                ## gamecon_args
                controllers.xarcade.enabled=0
                system.language=en_US
                ;system.kblayout=us
                ## Set you local time
                ;system.timezone=Europe/Paris
                updates.enabled=1
                # default : stable ; set to beta to get the next version currently being tested. set to unstable at your own risk to get the development version.
                updates.type=stable
                ## (string)
                global.videomode=default
                ## Shader set
                ## (none, retro, scanlines)
                global.shaderset=none
                global.integerscale=0
                global.shaders=
                global.ratio=auto
                global.smooth=1
                global.rewind=1
                global.autosave=0
                global.retroachievements=0
                global.inputdriver=auto
                ## Here is the snes example
                ;snes.videomode=CEA 4 HDMI
                snes.core=snes9x_next
                ;snes.ratio=16/9
                ;snes.smooth=0
                ;snes.rewind=1
                ;snes.autosave=0
                ;snes.emulator=libretro
                ;snes.integerscale=0
                ## Default cores for RPi2
                gba.core=mgba
                mame.core=mame078
                nes.core=fceunext
                ## NeoGeo emulator
                neogeo.emulator=libretro
                ## If you set libretro as neogeo.emulator, the line below sets the retroarch core (fba,imame4all)
                neogeo.core=fba
                n64.videomode=DMT 4 HDMI
                # n64.videomode=default
                  paradadf Staff @Thedirtybaby last edited by paradadf
                  @Thedirtybaby why did you change global.videomode to default? What kind of monitor are you using?
                  • Thedirtybaby
                    I am using an hdtv I had changed that when I was trying the different N64 video modes hoping that would fix the problem and I forgot to change it back. I just changed it back to CEA 4 HDMI and rebooted. The only thing that I can think of that I changed after the n64 emulator was working was I added two psx roms and added a few mame roms and adjusted the settings on them in the config file but put them back to how they were. Every other emulator is working (nes, snes, master system and playstation.)
