    Do-ability of an idea concerning mame/fba/fba_libretro roms
    Emulator Arcade/PC/Console
    do-ability idea concerning roms
    3295
    • KaraK_VarN
      KaraK_VarN last edited by
      Hello everyone and thank you for your great job on Recalbox.
      Following the dev of RB, i have decided to dedicate 2 rpi2 : 1 for console retrogaming and 1 for arcade.
      Concerning the mame/fba/fba_libretro roms difficulty with the specificity of the sets, i was wondering weither it is possible to mix the clrmamepro.dat with the same system used to check the hash of bios files via the recalbox manager under 192.168.1.xxx or not ?
      This would considerably clarify which rom is proper or not.
      hope i'm clear enough though 😉
      N.B : i have 2 rpi2, ps3 controllers, 1 xarcade dual stick
        do you mean we should write clrmamepro on pi ? 😄
        It's not really a question of feasability, but .. doh ... time consumming, and not even sure it's worth the sweat ... But technically speaking, it IS possible. But poor pi, not enough I/O speed to do it at a decent speed i'm afraid
          voljega Banned @KaraK_VarN last edited by
          @KaraK_VarN
          This would mean you would have to encode 3 hash for every roms (corresponding to the fba/fba_libretro/mame romsets) and roms names can even change from time to time (it's rare but it happens)
          Besides, roms hash are not the same depending on the romset type : merged, unmerged, etc...
          So this would be potentially mean that for each rom you should have at least 9 different hash to consider.
          Not to mention that even if the only way to be asbolutely sure that a rom to work is to take it in the right romset it cans still sometimes work when it has just changed a little, in another romset not far fom the targeted one.
          So in essence not only would it require an absolutely enormous amount of purely manual work, it would also be a bit pointless.
            Substring @voljega last edited by
            @voljega no, the trick would be to use the dats provided with recalbox (which are simple XML files) and check roms with the dats.
            Beside split/merged and parent/clone considerations, it's doable. But i don't think anyone would have fun coding such a thing, nor any interest for recalbox when other tools do it already much better
            • KaraK_VarN
              Thank you for these quick and precise answers.
              Now that i'm aware of what is involved, i reconsider my question.
              Alternatively, is it possible to list only the working rom names ?
              The user wouldn't have to search in the xlsx file which one to look for, depending on rpi version or emulator used.
              I tried that on my own, but i can't filter only "green/no comments" tagged files (because "green" is not a criteria of filtering).
              • KaraK_VarN
                Ok nevermind, i managed howto 😉 not an excel-specialist...
                  @KaraK_VarN I have plans to better code working status and add bios/driver and hardware system to the sheet in a not near future to make such automatic extraction more easy.
