    UXS - Problem scraping names from screenscraper.fr
    Community projects
    uxs scraping names
    • NaSHoOo
      NaSHoOo last edited by
      Hi @screech
      While working with customized mixes for UXS, I've found what appears to be a bug. Going to explain:
      I'm trying to scrape two (Spain) roms:
      Soleil (Spain).zip
      Story of Thor, The (Spain).zip
      When they're scraped, the gamelist.xml it's giving me these values:
      <path>./Soleil (Spain).zip</path>
      <name>Ragnacenty</name>
      <path>./Story of Thor, The (Spain).zip</path>
      <name>The Story of Thor: Hikari wo Tsugu Mono</name>
      This <name> tag, is this field in screenscraper.fr:
      Nom du jeux (dans sa langue d'origine):
      But those games has an alternative names in various languages, including Spanish. So I think UXS it's not getting the language preferences correctly, or doesn't scrape correctly the <name> tag.
      This is my language preferences in UXS:
      $RechMultiLang =es|eu|us|origine|fr|de|pt|jp|xx
      And, for more info, this is my customized mix:
      [MIX_IMG]
      $MIX_IMG_NAME		= Megadrive (ESP)
      $MIX_IMG_CIBLE_X	= 600
      $MIX_IMG_CIBLE_Y	= 400
      $MIX_IMG_NBIMG		= 10
      $MIX_IMG1_SOURCE_1	= 'screenshotTEMP|GameMax|medias/media_screenshot|path:image||350|RIGHT|CENTER'
      $MIX_IMG2_SOURCE_1	= 'logoTEMP|GameMax|medias/media_wheels/media_wheel_es|path:image|280||312|0'
      $MIX_IMG3_SOURCE_1	= 'logoTEMP|GameMax|medias/media_wheels/media_wheel_eu|path:image|280||312|0'
      $MIX_IMG4_SOURCE_1	= 'logoTEMP|GameMax|medias/media_wheels/media_wheel_fr|path:image|280||312|0'
      $MIX_IMG5_SOURCE_1	= 'logoTEMP|GameMax|medias/media_wheels/media_wheel_%%|path:image|280||312|0'
      $MIX_IMG6_SOURCE_1	= 'boxTEMP|GameMAX|medias/media_boxs/media_boxs3d/media_box3d_es|path:image||400|LEFT|CENTER'
      $MIX_IMG7_SOURCE_1	= 'boxTEMP|GameMAX|medias/media_boxs/media_boxs3d/media_box3d_eu|path:image||400|LEFT|CENTER'
      $MIX_IMG8_SOURCE_1	= 'boxTEMP|GameMAX|medias/media_boxs/media_boxs3d/media_box3d_fr|path:image||400|LEFT|CENTER'
      $MIX_IMG9_SOURCE_1	= 'boxTEMP|GameMAX|medias/media_boxs/media_boxs3d/media_box3d_%%|path:image||400|LEFT|CENTER'
      $MIX_IMG10_SOURCE_1	= 'regionTEMP|FixeMax|Ico-ESP.png|path:image|75|75|RIGHT|DOWN'
      Hope this info helps you, I love your tool, and just wanna make it better 🙂
      Thanks!
      • screech
        screech last edited by
        Hello,
        First : medias/media_wheels/media_wheel_es and medias/media_boxs/media_boxs3d/media_box3d_es unfortunately doesn't exist... So it's unnecessary in your MIX Template 😉
        Second : Can you copy/Paste you Scrape Profil ? I need to see what UXS try to catch (ELEMENT8 an 9 if you haven't change too much you profil 😉 )
        Normally, with $RechMultiLang =es|eu|us|origine|fr|de|pt|jp|xx it take the ES name first... So it's strange :S
        (wich UXS version do you use ? the very last one ?)
        • NaSHoOo
          Ups, I will erase the _es lines.... 😛
          This is my UXS preferences (I'm using the MIX profile):
          [GENERAL]
          $verINI	= '1.5.0.1'
          $RechFiles =*.*|*.xml;*.txt;*.dv;*.fs;*.xor;*.drv;*.dat;*.nv;*.bin;*sav
          ;Mask de recherche (séparé par des ';') | Mask d'exclusion (séparé par des ';')
          $Verbose =1
          ;Type de log
          ;0 = pas de log   1 = log standard   2 = full log
          $RechSYS =1
          ;Recherche automatique de Systeme
          ;0 = Fenetre de demande du nom de systeme
          ;1 = Recherche du nom de repertoire dans la liste de systeme + fenetre de demande si pas trouvé
          ;Par défaut dans le cas d'un scrape de tous les systemes, le logiciel fera une recherche et s'il ne trouve pas fera les requetes sans nom de systeme
          $RechAPI =1|2|3
          ;Ordre de recherche de l'API
          ;1 = CRC + System
          ;2 = CRC
          ;3 = FileName + System
          ;toutes modifications sur le champs ci dessus sera inutile
          [PROFILS_SCRAPER]
          $PROFILS_SCRAPER_1	= 'ScreenScraper-Recalbox v4'
          $PROFILS_SCRAPER_2	= 'ScreenScraper (MIX)-Recalbox v4'
          $PROFILS_SCRAPER_3	= 'ScreenScraper-Recalbox v3'
          $PROFILS_SCRAPER_4	= 'ScreenScraper-EmulationStation'
          $PROFILS_SCRAPER_5	= 'ScreenScraper-Hyperspin'
          $PROFILS_SCRAPER_6	= 'ScreenScraper-AttractMode'
          [ScreenScraper (MIX)-Recalbox v4]
          $PATHAUTOCONF_PathRom	=
          $PATHAUTOCONF_PathRomSub=
          $PATHAUTOCONF_PathNew	=
          $PATHAUTOCONF_PathImage	=
          $PATHAUTOCONF_PathImageSub=
          $ExtImage		=png
          $PICTURE_REGION =1
          $OPTION_MAJ		=0
          $IMAGE_SOURCE		= 'Screenscraper (MIX).jpg'
          $IMAGE_CIBLE		= 'RecalboxV4.jpg'
          $ELEMENT_1 		= 'gameList|root|Data|root'
          $ELEMENT_2 		= 'game|child|jeu|child'
          $ELEMENT_3 		= 'id|attr:game|id|value'
          $ELEMENT_4 		= 'source|attr:game|ScreenScraper|variable'
          $ELEMENT_5 		= 'path|value|%RomPath%|variable'
          $ELEMENT_6 		= 'emulator|value'
          $ELEMENT_7 		= 'core|value'
          $ELEMENT_8 		= 'name|value|noms/nom_%%|form:%FileNameBracket%'
          $ELEMENT_9 		= 'name|value|nom|value'
          $ELEMENT_10 		= 'desc|value|synopsis/synopsis_%%|value'
          $ELEMENT_11 		= 'image|path:image|%mix_image%|variable'
          $ELEMENT_12		= 'thumbnail|value'
          $ELEMENT_13		= 'rating|value100|note|value'
          $ELEMENT_14		= 'releasedate|valueDES|dates/date_%%|value'
          $ELEMENT_15		= 'developer|value|developpeur|value'
          $ELEMENT_16		= 'publisher|value|editeur|value'
          $ELEMENT_17		= 'genre|value|genres/genres_%%/genre_%%|value'
          $ELEMENT_18		= 'players|value|joueurs|value'
          $ELEMENT_19		= 'favorite|value'
          $ELEMENT_20		= 'region|value'
          $ELEMENT_21		= 'romtype|value'
          $ELEMENT_22		= 'hidden|value'
          $ELEMENT_23		= 'playcount|value'
          $ELEMENT_24		= 'lastplayed|value'
          $ELEMENT_25		= 'crc32|value|%crc32%|variable'
          $ELEMENT_26		= 'md5|value|%md5%|variable'
          $ELEMENT_27		= 'sha1|value|%sha1%|variable'
          I'm using your recomendation of form:%FileNameBracket% in $ELEMENT_8 to include the region in brackets, but it's not working as we are talking here:
          https://forum.recalbox.com/topic/3425/question-configuring-mix-profil-in-uxs/36
          • screech
            $verINI = '1.5.0.1' !!!
            Download quickly the last one 😉 1.5.0.11 ^^
            https://github.com/Universal-Rom-Tools/Universal-XML-Scraper/releases
            • NaSHoOo
              Problem solved!
              I'm a BIG DUMB! xD
              Thinking that I had the last version...
              Thank you very much @screech
