    Sega Mega Drive 3-button setup (GPIO)
    Emulator Arcade/PC/Console
    sega mega 3-button setup gpio
    3892
    • CaffeineFiend
      CaffeineFiend last edited by
      I've been following this guide when connecting wires to the GPIO pins. The original Mega Drive / Genesis controller has an A-B-C button layout.
      The guide says nothing about the C button, nor does the emulationstation setup. How do I configure the C button? Do Y configure it as X, Y, Select?
      Thanks!
      supernature2k 1 Reply Last reply Reply Quote 0
      • supernature2k
        supernature2k @CaffeineFiend last edited by
        @CaffeineFiend
        I really don't see what you are trying to achieve. Are you wiring each Megadrive button? If so, put the C to Y.
        There was a way to connect DB9 controllers but I can't find it back. Check on the forum.
        CaffeineFiend 1 Reply Last reply Reply Quote 0
          anyway, using an original MD pad has a BIG drawback : no selct key, no hotkey. And the most logical solution was to use the DB9 driver, not the GPIO one ...
          • CaffeineFiend
            CaffeineFiend @supernature2k last edited by
            @supernature2k I'm refurbishing an old arcade cabinet, using the original controls, which limits me to 3 buttons. I am therefore only going to emulate the Mega Drive, as it's perfect for this scenario. I will try connecting it to Y.
            • CaffeineFiend
              Wiring the Mega Drive C button to Y solved the problem... I had it wired to Select (because why not? :P)
              Maybe it should be written in the guide?
                voljega Banned @CaffeineFiend last edited by
                @CaffeineFiend what about 6-buttons megadrive games ?
