    Adding games without dragging
    adding dragging
    • Bluster Kong
      Bluster Kong last edited by
      I'm getting a Pi3 soon and I plan to install recalbox on it, but, using the samba network share stuff can you add files to the SD card without dragging them and by just clicking "upload file" or something?
      I'm asking because it would be way more practical to add my ROMs that I have saved to my Google Drive via my phone
      So can you also add files via a button or do you need to drag them?
        paradadf Staff last edited by
        Of course you can. Just use a file manager/transfer app and connect to your Recalbox though SAMBA, either with the host recalbox or the ip of your Recalbox.
        • Anonpebbles
          Anonpebbles last edited by
          This post is deleted!
          101.4k
