    Is it possible to seperate Select and Coin?
    GamePad/GPIO/USB encoder
    possible seperate select coin
    3350
    • cronos1
      cronos1 last edited by
      Hello,
      my question is: is it possible to separate the select button from a coin acceptor. For example if i play a SNES game i want to use the normal select button, but if i play a game with mame and its need a coin for start i want to use a physical coin acceptor an the select button who i use for other emulators should be ignored so you dosnt can press select instead of pay a coin in the acceptor.
        to say it simply : no. Retroarch does map select to the arcade coins
          voljega Banned @cronos1 last edited by
          @cronos1 but you can connect your coin acceptor to the select control.
          what's the point of deconnecting select in arcade games anyway ?
          • lainbebop
            lainbebop last edited by lainbebop
            Is it possible to map the SELECT to 2 button ?
            ie : have a SELECT and a COIN button, both mapped on "select command" ?
            Bartop Metal Slug Home Made :)
            https://forum.recalbox.com/topic/7656/my-mini-bartop-metal-slug/
              Substring @lainbebop last edited by
              @lainbebop no
              • screech
                screech last edited by screech
                You cannot MAP 2 buttons on 1 function, but you can WIRE 2 buttons to the same "PIN" (GPIO or Xinmo or what you have ^^)
                The finallity is the same, you will have 2 buttons known as one by the PI.
                You can try that with a cab... but not with a "standard" controler.
                lainbebop 1 Reply Last reply Reply Quote 1
                • lainbebop
                  lainbebop @screech last edited by
                  @screech great idea !! Thx;)
